Ok so Ive been trying to find out the cleanest way to do the wiring. I've found a lot of information as far as how to wire it when I put it all together.
I looked up how Series 2 Rb25det are wired into a s14 being I heard its easier because the Main harness connector from the "dash harness" to the EFI harness just needs to be repined.
So heres the start of some info from
http://zilvia.net/f/showthread.php?t=397649
Copied***
(See Sileighty_85's
http://zilvia.net/f/chat/332057-project-rb-how.html thread for an extensive guide on the actual swap in its entirety.)
Let's begin with some of my issues and observations I made between my own motorset's harness and those of others I've come across through my searches.
RB25 Series 1 harness•2 blue Relays near ECU & F3 plug
•Wider MAFS connector for green label 'J60' 5-prong MAFS
RB25 Series 2 harness•1 blue Relay near ECU & F3 plug
•Narrower MAFS connector for pink label 'E60' 3-prong MAFS
Useful note: Fourth-gen ('95-'99) Maxima MAFS are exactly the same as S2 RB25 MAFS so they are interchangeable. The part #s are the same, as well as me being able to confirm this after finding out I was sent the wrong MAF with my motorset and hitting the local U-Pull-A-Part.
I am also led to believe that because of the ignitor chip/coilpack difference between Series 1 and 2 RBs, there is a discrepancy in the wiring. In the following diagram, it instructs to somehow re-pin two wires into one terminal. The first is what should be a solid RED wire (for "ignition relay power") from terminal #4 to #17, the second being a WHITE with BLACK STRIPE wire (ECCS Relay power) from terminal #24 to #17 as well. This is where I feel the wiring difference between S1s and S2s comes into play. Since S1s have 2 Relays and S2s only one, it looks like S1 owners have to find some way to make two wires merge into one terminal.
Disclaimer: I am NOT 100% on this, probably not even 75%. I have come to this conclusion through what I have researched so far, along with the complete lack of any solid red wire on my S2 motorset's harness originating from the ECU or M63 (F3) plug.
So instead I looked up the 300zx F2 plug
