I H8 UR DSM wrote:all this can be found through those links we posted...
from P2M: with my estimates in ()
"When you are ready to do the SR install yourself, make a check list of things you need to do with the install. From our experience, we recommend to do the following same time with the install:
Air filter kit
Downpipe upgrade (150)
Catback upgrade (500)
Boost gauge (115)
Turbo timer (90)
New clutch kit (300)
300ZX fuel filter (70)
300ZX TT or Supra TT Denso fuel pump upgrade (120)
Stock or aftermarket intercooler kit (1000)
300ZX NGK / Denso spark plugs (gap to 0.030) (50)
4 quart of 10w30 generic oil (to be changed out at first 500 miles), afterwards Synthethics welcome. (50)
2.5 qt of tranissmion fluid (30)
Nissan SR20DE oil filter (5)
When you have all the parts ready for the swap, you must prep the SR motor before dropping it in:
Removal of the stock SR AIV solenoid and weld the recirculation port off the turbo O2 housing shut (S13 SR only).
Check oil pan for any signs of dent or damage.
Change to the KA speed sensor as well as the transmission sensors.
Check the condition of the fan clutch. Ditch the stock fan clutch if bad, and run aftermarket electric fan.
Check stock turbo for shaft play and condition. Check condition of the SR engine mounts, KA engine mounts can be used but we highly recommend upgrade to the Nismo 3pc mounts ($280) or brand new Nissan KA mounts.
Check condition of the drivebelts, replace if needed."
and from HT:
"How Much does it cost?
$2400 SR20DET engine and 5 speed transmission
$80 - $200 Shipping
$309 - $339 Performance clutch kit
$139 - $229 3" downpipe
$849 - $999 Intercooler Kit
$129 - $220 Blow Off Valve
$129 Hi Flow Fuel Pump
$390 - $650 60mm - 80mm full cat-back exhaust
$55 K&N filter and aluminum intake adapter
$50 Motor oil, PS fluid, transmission oil, coolant
$99 Radiator hoses and heater hoses, belts
$35 Oil filter, fuel filter & plugs
$14 Heat wrap tape
EZ Install Kits Here
Optional
$65 Trunk mount battery box and cable
$150 Boost and Fuel Pressure Gauges
$149 Electric Fan Kit
$50 - $125 Manual Boost Controller
$250 - $550 Electronic Boost controller
$109 Turbo Timer
$220 High-flow cat
$550 Lightened flywheel
$275 Lightweight Pulley Set "
you get an engine that is complete, it should come with everything needed to do the swap EXCEPT the intercooler, intercooler piping, blow off valve, and downpipe. We recommend replacing the clutch and fuel pump also. Along with the engine and transmission, you should receive the following parts:
Top Engine Harness ECU engine harness ECU Lower Engine / transmission harness Power Steering pump Power Steering high pressure Line Power Steering reservoir if SOHC car, DOHC has correct reservoir Alternator - can use some DOHC KA Alternators Starter AC compressor Ignitor Chip and assembly Wastegate solenoid controller Turbo inlet pipe Turbo outlet pipe Canister Engine mounts MAFS - SOHC can be wired to work Turbo Wastegate actuator Cam Angle Sensor Throttle Body Turbo exhaust outlet extension Bell housing bolts
Sometimes engines that are missing things like the ECU or with a cut harness are offered at a discount from Heavy Throttle or other vendors. Be aware that some parts are easier to find than others. Currently main engine harnesses are difficult to find. ECU, MAF, CAS, Ignitor Chip - these things are relatively easy to find."
alll this can be found by searching the boards, and links. thanks
jesse
How is a 300sx fuel filter 70.00!!!?? I bought one for 10.00 at my local auto parts store.
