Subframe installed onto car. Rubber isolator and one collar used above subframe.
Removed bushings from Diff. Checked stackup of solid bushings bought off E-bay. Bushings are .026" too thick and will need to be sanded in order for the diff to sit flush.
daconkiftador wrote:Your progress looks great! I was wondering, how exactly did you apply the isopropyl alcohol.. did you put it in a spray bottle and just spray it everywhere you wanted clean, then scrub? Im looking to strip and re-undercoat my wheel wells as well as the underside like you did, so any tips would be awesome, thanks! Keep up the good work.
I pressure washed the areas after applying a degreaser, then sanded with 220 grit, and finally washed with the 90%+ isopropyl alcohol. I used the alcohol but there are some paint prep liquids you can also use. Just poured it onto a shop rag and scrubbed then wiped residue with a clean shop towel. The alcohol will take some of the paint off, dry then paint. Not too difficult just time consuming.
s13drifter88 wrote:sweet job bro... do work! lemme kno how those circuit sports arms work out. im thinkin of ordering them for mine after my KSport Pro coilovers come in. Keep up the good work, peace.
Sure thing man. Should have the rear reassembled by end of weekend.
The car wont be running for a while since Apexi is having issues with the New Hand Commander
. Ordered it in mid April and still havent received it. Here is the response from NenGun regarding the delay.
"Hi Matt,
Thank you for your order with Apexi, unfortunately we haven't received in supply the Apexi Power FC and New Hand Controller by the end of June as notified earlier by our Apexi distributor. For some, you have waited a long time, several months in fact and others have just recently ordered. You have received delay notifications and new updates and unfortunately we have not been able to meet these deadlines. We sincerely apologize for these hassles, as I'm sure all of you are desperately wanting your part.
We are also desperately wanting these parts for you. We have been in several discussions with our Apexi distributor and we are so very sorry to say there has not yet been a new confirmed date when these will be arriving in stock.
Please understand we are trying to do everything we can to get the Apexi parts! We have been made to understand that there is a problem with the new Hand Controller. Apexi are working very hard to ensure all Hand Controllers are fixed but it is taking time. Please remember this problem is world wide, so every Apexi order has been delayed.
We ask that you please continue to be patient as Apexi resolve the issue. As always, we will keep you updated as to when your part may arrive. "
