Read and heard that at idle you should base your afr off of maximum vacuum. My car has the most vacuum at 12.5-13.0 and had a smoother idle than when at stoich. Base off posts on the net and talking with some other car ppl some like to have stoich afr's at idle and others a little richer.s13drifter88 wrote:12.5-13 is awful rich for idle. Ideally idle should be around stoich or a little leaner.
Planning on messing with my airflow curve voltages since I found this VQ Table https://spreadsheets.google.com/ccc?key ... y=CIyvhsED on SR20 forum that I'm hoping will point me in the right direction.
Thanks for the input s13drifter88 at least someone is reading this.
