Bumnah »
https://forums.nicoclub.com/bumnah-u39849.html
Thu Jun 11, 2009 6:58 pm
Update.
Got up at 7:30 out the door by 8. Left to get the car corner balanced and aligned at my friends shop in WV (2.5 hour drive from my place). Got on the highway, and started having all sorts of minor issues. The car would lose power for a split second, we noticed because the gauges would randomly reset. On the highway we felt a slight bog when this happened. Drove 10 miles figured it wouldn't do anything more. Front right fender liner came undone a bit. Made my friend and I even more nervous. Contacted my friend at the shop, asked if he could pick us up if we broke down. Unfortunately he had to pick up another customers car and wouldn't be able to help us out if we broke down. So like a beaten dog I put my tail between my legs and turned around.
The trip back was smooth, no issues. We felt comfortable enough to drive to another town and see if I could get the car inspected. Drove it there and back, no problems. By the time we got back to my place it was 2 hours and we would've been to our destination by that time if we hadn't turned around.
My friend and I grabbed lunch, decided to grow a pair of balls and go on the adventure we originally planned on. We left at noon and got there around 2:30. At three they started work on my car.
Pix:
Car finally on the rack!
Weights before adjustment.
Alignment:
s***ty cell phone picture of the car as she sits now. I'm very happy with the stance.
It was an expensive corner balance and alignment.
Honest review: Best alignment I've ever had. Everything feels really good. He spent close to 5 hours balancing and aligning the car. If I were really being critical of the alignment, I would have to admit I *THINK* it pulls to the right slightly. That could be due to my street tires though.
I was however, NOT happy with the corner balancing. For two reason; 01. He adjusted the ride height by lowering the spring perch, and not the lower collar on the KTS coilovers. I told him how they worked, but he wasn't listening to me. Since my friend worked there I didn't press it too hard. I had to bite my tongue on it. He also didn't balance the car with my track wheel/tire setup on. He said since the street setup was similar in size to the track wheel/tire setup it would be fine as it. Perhaps I'm a bit too anal retentive, but why not use the track wheel/tire setup if they're available? I brought 'em with me!
He did take time and looked over my work and said everything looked good. He also checked the pre-load on my sway bars. Everything checked out fine.
I believe I will save up for some scales for my personal use. Rather do that than pay some else for a less than ideal job.
This weekend is my first track event, VIR - Grande course.
I'm not going to push the car too hard. I'd like to get a feel for her at first. As time goes on, and I feel more comfortable, I'll push harder. I'm very glad this suspension build went as smoothly as it did. Hopefully I get a lot of track time in this year. My goal is to do 5 events this year.
When I return from my track event, I'm going to swap in my tail lights. Can't wait to see how they look, now that I've lowered the car.
Driving feel:The car is very well behaved. It feels solid. The body roll is obviously much less. It tracks well. I haven't felt any odd bump steer. Driving over uneven road surfaces doesn't cause the rear end to lift up on one side. Even with the spherical bearings, and aluminum rear sub frame bushings, it was VERY streetable. KTS coilovers are still set to the softest setting however. Leave the shop it was storming, and the car drove well through the puddles. VERY satisfied with the suspension.
The aluminum rear bushings are def. transmitting a lot of noise. The slight rear end off throttle grumbles I used to hear at certain RPMS are much more prominent. The differential noise is much more apparent as well. The worst of it all is, I can hear my gear selections after ever shift. It's transmitting that as well; comes across as a loud "clunk" every shift. I did a quick look to see if I was missing fluid, but I'm not seeing anything. I do hear a slight grinding noise, I think that might be the drum ebrake setup being off slightly. All this will be checked out after I get back from the track.
Sorry for the novel.
Thanks for looking at this thread. I may updated this thread once more with pictures of the tail lights and front lip installed. I hope it was useful to someone.
