Wind noise from moonroof
All things Altima Coupe.
raftah
Car: 09 Altima Coupe
Getting a lot of wind noise from the moonroof when I'm on the highway. Closing the cover makes it quieter but it's still there. Any ideas how to fix this?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
My first check would be to make sure that the gasket is relatively clean. Next step would be to make sure that the panel is sitting in the right spot relative to the roof to make sure that nothing wore out and screwed that up. If those check out, I think a gasket replacement is in your future.
Hope that helps.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
the converted wrote:
Fri Dec 18, 2020 6:21 pm
Yep, dirty gaskets are the number one, two, and three issues. Front, rear and sides, everything else comes after. :dblthumb:
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
raftah
Thanks guys, I will troubleshoot with these ideas.
