Moon roof wind noise
All things Altima Coupe.
steveo94
Hello! I'm new to this forum. I have an 08 Altima Coupe. When I hit speeds of 80mph or higher I get a high pitched squeal from wind noise. I took it to the dealer and they said it was "normal turbulence". It is quite annoying and I haven't found anyone else that has the same problem. Is there a solution to this problem?
Thanks in advance for your help!!!!
lilojoj
Car: 2008 Altima Coupe
welcome! solution = stop speeding
lol
um it probably has something to do with those rubber seals. something has to be leaking
mcheddadi
Car: R8
steveo94 wrote:Hello! I'm new to this forum. I have an 08 Altima Coupe. When I hit speeds of 80mph or higher I get a high pitched squeal from wind noise. I took it to the dealer and they said it was "normal turbulence". It is quite annoying and I haven't found anyone else that has the same problem. Is there a solution to this problem?
I had that too because the plastic panel underneath the car's engine compartment hadn't been placed back the way it was supposed to after they fixed my plenum hose leak.
skop3.5
Car: NIssan Altima Coupe 3.5 SE Premium Package
do you have a sun deflector? or that black thing that goes on your sunrof? i had that wind noise i thouhgt it was the seals i took that sun deflector and the problem was fixed
DarkKnight22
skop3.5 wrote:do you have a sun deflector? or that black thing that goes on your sunrof? i had that wind noise i thouhgt it was the seals i took that sun deflector and the problem was fixed
Holy huge sig batman!
I have the same sort of noise, sounds like something flapping in the wind when i'm doing over 65. I've narrowed it down to something in my headliner, but I can't figure out what. Punching it doesn't help either....
Oh and I don't have a deflector
steveo94
Awesome! I'll give that a shot!
Thanks!
DAAN.
XXL signature right there :P
