Doesn't matter, your oil will get dirty, and if the filter doesn't do it's job it gets dirty quicker, reduces performance, increases wear, reduces engine life. Not to mention, if you change you oil more frequently you spend more on oil. If you're a performance nut who changes it often, you can spend a few bucks more on a good filter, not the cheapest. FRAM filter (orange one) around here goes for about $3.80 for the S13 SR, Pureone is, again, about $5.50, not much more and worth it for a good filter. For the record, I change the oil in the SR about every 2 months or 2k miles, whichever comes first since it's not driven much.dnlx5 wrote:good point if i change my oil before its really dirty, aside from getting broken filter bits in my engine all i should really care about is flow and hey i can use the money i saved not buying a 20 dolor filter on changing my oil more frequently and with beter oil im not too experienced but seems logical, especially for us performance nuts who abuse our engines
I don't know, but the pic is on XAT racing's website on the home page.TchouikoS13 wrote:All this FRAM talk and such... Who's engine bay is this anyway?
uh no i don't think so.5 or 10 passes down a 1/4 mile strip isn't even as close to a car running 10,000 rpm for 500 miles straight.Think about it for a minute.Chaotic_Warlord wrote:I know I said FRAM was an official sponsor of NASCAR, but I was mistaken. They are actually an official sponsor of the NHRA, which actually means the engine go through about 20 times more stress per race.
I definately don't think the NHRA would allow garbage filters to be used, considering the amount of down time they have to take when a car does blow an engine on the track.
Yo dude, you were at the Formula D event today too? It's a small world and a really big forum.Vernal wrote:If Fram is so bad then why would they use it on formula drift cars.
No I wasnt I jacked that picture from the "FORMULA D" thread.Chaotic_Warlord wrote:
// threadjack
all bs why would they change their filters every 20 miles? if u see a fram filter on a d1 car dosent mean that they are garbage..hpmachine wrote:Like I said earlier, they may change the oil after every event. By the time the filter comes off of there it may only have like 20 miles on it.
I guess it's just oil too then huh? With your attitude why spend money on a good filter or oil, it's gonna throw a rod eventually anyway. BTW, WIX manufactures many OEM filters for automakers, and unless I'm mistaken, they make Nissan's too (I could be wrong about that though). I have an SR, my professionally rebuilt SOHC KA spun a bearing in March, don't know if it was the FRAM filter or maybe a crappy rebuild. I didn't start this thread just to hate on FRAM. I saw a pic of an SR in an engine bay that obviously had a lot of money in it and didn't see why someone would put one of the cheapest oil filters they could buy on it. Btw, some say that bc of FRAM's crappy anti-drainback valve it lets dirty oil drain back into the pan and can cause noise in the valvetrain at startup (read ishkabibble's link). I had this, even after I had the entire timing kit replaced! I pulled the valve cover more than once to see if the guides had self-destructed again, they hadn't, nor had they when the motor finally died. The oil pump was new too. So, maybe it was a bad rebuild, maybe it was a crappy filter bc I had always used FRAM. I too thought people just hated on FRAM bc they were cheap filters, after this mishap, I began to think differently, did some research, and found some supporting evidence. So, I won't use them again. My .02RB20DETodd wrote:fram is bandwagon hate, its a ****in filter!! half of you asses have a "OEM" nissan filter on your sohc ka with a short ram intake that will prolly throw a rod in the next month or two, even with the best filter the ka will throw a rod
yessir240 wrote:every time ya buy a fram filter i make money.
