Chally »
https://forums.nicoclub.com/chally-u110.html
Wed Jun 04, 2003 3:52 pm
Quote »Once the hash on the runner walls is exposed, fuel will be more evenly atomized and more evenly dispersed through the chamber, resulting in a cleaner more powerful burn. [/quote]
Just a point, fuel doesn't get mixed with air in the plenumn chambers on the Q's. The fuel gets injected just before the intake valve.
As for cleaning them out, the best method I've found is Removing the Plenumn & soaking with a good degreaser.
I've run some, supposedly "GOOD" cleaner through, & the Plenumn was still reasonably dirty. With it off, I could get the alloy to shine again. (on the inside)
As for spinning the wheels, I have 225 tires fitted, & now I can spin them for 5-10ft & then it just shoots off. If I tramp it & turn at the same time, I can do huge power slides, even when turning a corner at 30mph, if I tramp it, it just goes sideways! Heaps of fun.
Saying that though, I have fitted New Knock sensors, New Temp. sensor, New Thermostat, Cleaned the terminals on the Throttle Switch, Crank Angle switch & Air Meter, with a fine steel brush, & chemically cleaned the "sensor" plugs as well & then sealed them to stop moisture getting in. I also use the BEST fuel I can find (98 octane)NGK plugs & a Good quality oil, (Valvoline Durablend, 10w-40) & it all adds up to giving those extra HP you need, & of course want.
