who has added the OEM foglight kit to a SL?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
trellaine
Car: 2010 VersaHatch SL/Nav package
Promise Land wrote:good to hear it helped a little. It's very easy to do. So easy a caveman could do it?
I am lower than a caveman :( I have a friend coming by to check things out. I have one question: do I have to take the bumper off in order to find the wires and attatch the lamps/bolts etc?
Or will have to unbolt the bumper to access all this? I have to get under the car? (back issues for me)
This friend of mine has a bit of a language barrier so I want to be able to explain things best I can.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
you don't need to take the bumper off. The wire is below the headlight, and you can see it if you stand beside the car and look at the back of the headlight. You can also take the air guide off the top of the grille and reach down behind the bumper to tighten the bolt to the back of the foglight.
trellaine
Promise Land wrote:you don't need to take the bumper off. The wire is below the headlight, and you can see it if you stand beside the car and look at the back of the headlight. You can also take the air guide off the top of the grille and reach down behind the bumper to tighten the bolt to the back of the foglight.
hmm I'm here now with my friend. All I can see is wires wrapped in black covering? This is what I see from beside the headlight ?
Thanks
P.S My friend found the wires and installed my fog lamps, lucky me with the help and lucky me for this thread/video-thanks!
Return to “Versa Technical Discussions”
