What was done to your 240 today?
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
My turbo blanket came in. :)
breaker77
i gutted it.
now im getting rid of sound deadening.
:crazy:
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
^ I really hated doing that.
s13sickboi
Car: 1997 Nissan Hardbody XE
bought my headgasket kit today
feoo
Car: '89 240sx Coupe
dropped the tank and patched a stress crack. how much do tanks usually go for?
island240_s13
Car: 1993 nissan240 fastback (s13 twincam)
washed it down applies tire shine then frowned at my rusted out hatch!
slip'n'slide
Car: 1991 Nissan 240sx coupe
Today I installed my wheels on my 93 vert (5 speed),fixed my battery terminals because the guy before me only knew how to operate a hack-saw and molested my poor vert, and for my coupe, I bolted on my motor mounts and alt bracket and misc other motor parts. Future ka24de-t. :naughty:
95s14green
Car: 1995 240sx s14
tried to get my s14 inspected. it failed. so i went for a drive to cheer me up haha.
breaker77
speedeast wrote:^ I really hated doing that.
understatement of the millennium
speedeast
breaker77 wrote:understatement of the millennium
I didn't have dry ice when I did mine. There is a little bit left on the rear wheel wells, but I have some dry ice now!
driftneil
Car: A pile of cars.
Installed drilled and slotted rotors and new pads on the rear of my kouki....Oh and had to swap out a stuck rear pass caliper...f*** you rust, you wont beat me!
98blackbell
Car: 1995 Nissan 240SX SR20DET(STOLEN)
1993 Nissan 300ZX 2+2
2006 G35 Coupe
1998 Chevy Tahoe 2DR 5.7
1975 Datsun 260Z Turbo
Installed a new shifter!
Now i have to take the factory sticker off!
rsmithdrift
Car: 1993 240sx fastback se.
Wiped off the 6 inches of snow and ice and got stuck pulling out of the driveway. God I hate open diffs.
driftneil
98blackbell wrote:Image
Do you have a 6 speed?
feoo
gas tank issue revisited. got it up in the air and loosened the driver side strap. pebbles were embedded in the rubber piece that runs between the strap and the tank, which id assume caused the leak :tisk: so i cut out the ruined portion of the rubber piece, got some plumbing repair rubber sheet stuff from lowes and used that as a substitute. then jb welded the hell out of the little crack. hopefully it holds!
f*** pebbles
Street79
Car: 09 Sentra 93 240sx
Nothing at all for real the car is under all snow covered all the way around :frown: :frown: :frown: :frown: :frown: well got to go dig her out now... ;)
240sxcl50
Car: 95 s14
a friend pretty much did every thing i helped anyways removed the clutch dampner useless crap box wired up oil presure gauge and water temp and washed and waxed it.
chaos2000
Car: 89 240sx HB (s14 sr20det)
90 240sx Coupe (nothing,yet)
finished putting together my s14 sr after the #2 piston blew up, now just waiting for one of my friends to help me put it back in and be up and running again, lol.
mvpruett
Car: 1989 240sx
I power washed the engine bay and pit a brand new optima red top in it, got it for free!!! I also pit a new stereo in it too. It was a good day for my coupe.
EnjoiNismo
Car: 93 240sx
Watched the roommate fit new rims
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
found my vacuum leak and fixed it. cleared all codes. added some oil. and found out i have a seized clutch fan. yaaaaaay
Lobo240sx
Installed my 550cc injectors. Pretty easy straightforward install.
Unplugged the fuel pump and started the car till the pressure was down.
Take the covers off then I use vise grips. You can even use a napkin or paper towel or cloth to cover the plastic. Pull straight back don't twist them out. I know it feels like the right thing to do and have done a lot of research on taking injectors out. Even as far as putting them in the oven but I really don't want my house smelling like gas or have an explosion. lol.
Voila!!!
Now for the new injector. Set it in there don't hammer or push it in there. Get your injector cover with the bolts and tighten them going back and forth between them as shown below. Make sure when they are getting tight they are seating properly. Look at your other injectors for reference.
Repeat the above process for each one. Plug fuel pump back in. Turn key but don't start it immediately. Listen for the hiss in the front and wait till fuel pump kicks off in the back. Make sure that hiss isn't fuel pissing out too. No problems started right up but you get the idea.
Peace.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
yesterday, replaced the clutch line with a braided ss one, changed oil and and gave it a bath. today, drove it to work and it got dirty again then filled it with 76 premium.
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Bought a oem front lip for my zenki
420sxWETDREAMS
Car: 1991 240sx Hatchback
breaker77 wrote:i gutted it.
:crazy:
It sucked for me too.....but worth it. :rolleyes:
420sxWETDREAMS
Got rid of my nasty rust on my rims from sitting and had to use my Dremel on one.
driftneil
I drove it......What the hell else do you do with cars?
biggie
True I drove my Coupe Friday, that was the first time in like a month. Vert still hasn't been out in like 2 months.
Did build some DIY car ramps out of 2x6 and 1x6, to get the cars off the ground enough to get a jack under them.
driftneil
biggie wrote:True I drove my Coupe Friday, that was the first time in like a month. Vert still hasn't been out in like 2 months.
Dont starve it for attention, it will hate you for it......And we all know what happens when our cars hate us......
the a3k
Car: 1996 Black S14 RB25
installed my bride shift boot and new shift knob then drove it to work
