matt0941 wrote:But why would it work in conjunction with the ECU... I was under the impression that it was a full standalone system. Thanks.
Sorry for the confusion Matt, the SDS is a standalone. But the cheapest version only controls your fuel maps. It doesn't control ignition. So that would mean that your stock ecu would still need to control the timing.
The more I think about, the more I would go with my original suggestion. A complete standalone system to control everything. You will pay more then all the other methods. But just barely.
After all, anything worth doing, is worth doing right...
I'd rather see you go cheap or used on a turbine, then the ECU stuff. I got my TO4E used, worked for the last 2 years just fine.
I'll look online a little later for some good standalones. I know of quite a few more besides the famous Haltech, SDS and TEC3.
I'll post my findings, with some detailed info on each.
WD
