MinisterofDOOM wrote:I've always preferred blowers over turbos as well. They suit my tastes better. I've always been a low-end power guy, which leaves me sort of the odd man out in the Japanese car world where peaky low-displacement powerplants are nicely complemented by peaky turbos.
Turbos can certainly lead to nice torque curves (look at the Cobalt SS for instance, with 260t-lb at 2000rpm), but supercharged V8s and turbo 4s are entirely different worlds. Especially when you're dealing with such a broad-ranged V8 as the VH, which couples low-end torque AND high end hp nicely (maybe not out of the box, but a mere ECU tune removes the "gap" and leaves you climbing through the whole tach with plenty of thrust). If I were to build a monster VH, it'd have a high-rpm valvetrain for 8000rpm redline and a blower for monster torque off the line. Perfection.
I have built a couple of turbo cars.....all of them making well over 1000 hp...one of them with a displacment of 250 inchs and another with a 400 cu in displacment. The little engine made 1400 Hp and the larger around 2500 hp...both of them seen several hundred street miles.
All I do is hang around V8 turbo guys.
A blower engine will really screw up the look of most cars..unless your ok with a big ugly cowl and none of them make much power. Any refined engine for example from BMW etc will have twin tubos so that should tell you something.
Its all about the size in the turbo& wastegates......I would never want any kind of bumped up hooded noisey supercharged car when a properly sized turbo will rip you neck off in comparison to a supercharger.
You get to keep the hood flat and you have an almost noisless engine that will make you crap your pants upon hitting the loud pedal...superchargers are for guys with boats... and who want to look cool at cruise nights
Turbos belong on real street cats that like the sleeper look...and will go for 100k miles..They are priceless.......and if you have never had the chance to take a ride or drive something around 1000 hp you will never have any idea of what I am talking about.
The Q car is a natural for twin turbos. The VH is a perfect engine for turbos...this engine will make an easy 1000 hp on some pump E85
I have not seen a Q the way I think it should be done yet....I will do my Q but I have another twin turbo I have to finish building first...
You can keep your superchargers......
Ideal QTwin 50mm with some built in wastegates with some top feed injectorswith the chevy 480LE trans all controled by a BS3 ECU which will control the trans shifts as well. The engine needs nothing but lowering some CR and a forged piston......stock cams are perfect.
