White Comet »
https://forums.nicoclub.com/white-comet-u42048.html
Sun Mar 08, 2009 6:32 pm
good stuff on the gsr cams
small update
well for starters, i finally have the turbo line fitting sorted out (thanks to logan for all his help) but its male x male 3an to 7/16. mine will be in tomorrow, but they only come in packs of 2. if anyone else needs one let me know, and i'll hook you up. i'm going to be making mine an oil restrictor since this way will be much cheaper and faster then buying one. while waiting for that to get done, i made progress in a few other areas. i did a little research and decided to pull the lower trans harness to clean it up even more.i got rid of all the trans sensors except for vss and reverse. the other ones were completely cut out of the harness and i extended the plugs that go to the fuse block to reach inside the cabin. the portion going through the bay was covered in the last of my techflex and run through the same opening everything else goes though. i think its kinda funny that all my wires going into the bay fit through the smallest of the 2 openings for the ac . to take care of the unused ac hole, i ordered the ac delete grommet from nissan. it'll be here friday and it costs $5.^ the wiring in the bay. as you can see i slit the ac grommet and was able to fit it on so nothing would rub through.
heres the plugs in the cabin side
while iwas messing with the trans harness i replaced the reverse sensor with the one off of the ka bellhousing, but for some reason the plug to go neatly into the trans harness was cut and it was spliced in with speaker wire. it was no big deal, kyle just spliced that sensor into the the existing plug and everything works nicely. but what do you think nico, shoudl i get tom to do my wiring next time?i ked, i ked
i also ran the 0 gauge into the splitter, but still need to bring the other 2 sides into it
the map light is also spliced in and the headliner can go back in
while i was working on my wiring, my brother quickly made a bracket for the seatbelt on the passenger sidethe driver side was mocked up but the bracket wasn't made yet.
just a quick pic of the b&m installed
heres the painted cas cover, waiting for a new gasket before it goes on
i got the clutch hardline hooked up to the slave cylinder with my spl braided line, and i bypassed the dampening box while i was at it
while my brother was underneath the car, mocking up the lower harness, he discovered this little gem so now i need to pull one off of a junkyard car.
but while i was inspecting the damage, it didn't bum me out enough to stop me from taking a pic of the nissan hamburger
all teh next day, all i did was clean and get the car ready to be wheeled out. heres how everything was looking when i left on friday
i was going to go over before work on saturday but i was feeling pretty sick, so my dad and brother took care of rolling it out. and i don't have any pics of it, but my brother also installed the c pillar bar. he had to cut the c pillar plastics but it came out nciely. thats all for now, i'll have more later seeing as the turbo can go on soon
