no not yet and i'm pissed i haven't gotten around to seeing it yet. i read the book back in highschool before it was cool i just havent had time to see the movie yet.idahotuner wrote:hey jeff have you seen Watchmen yet?
lol, no vid of it running yet, but it doesn't need much more to run. i'm just not doing anything to it lately so i can work alotDriftBoy07 wrote: Ill bet you I have mine running first .If you show me a vid of it running in your next post, Ill steal your car!!
lol wana bet hahaRazi wrote:No, I believe it's a Porsche 944.Gets owned hardcore.
the pineapple bushings are for s13s and s14s. the instructions telling you to leave the sleeves are for s14s only. for s13s you removed the sleevesle_ryan wrote:hey, i got my pineapple bushings for the rear subframe today, but the install directions say NOT to remove the inner sleeve .. how did you do yours?burn the rubber, and leave the sleeves or what ?
not sure, i'll have to check. it was $1 from heavy throttleBumnah wrote:what is that a 1/8npt to 1/8" barb? or 1/4 npt to 1/8" barb?
no prob, good luck installing themle_ryan wrote:ah, see, i have S14, hey thanx again .
the rust gel came from walmart iirc and yep, no shields back there. i got the pics and damn, that really is the entire side, front to back. i'd still take it to drive around for the right price. the biggest concern is the rear qphbpignosePA wrote:ok i got a much later start today, i was so tired i slept in since ive been workin so much.
you get my pics of the s14?
i was re-reading your subframe build up
2 things.... where did you get the rust gel stuff
and are you not running dust shields back there?
i just flippin noticed that
check my thread late tonight
Just an FYI, I bought the pineapple bushings for my s13 and went to install them last weekend but they are too small if you remove the collars... so for BOTH s13 and s14 LEAVE the collars in or they will be too small and fall through. Wanted to clarify that if possible...White Comet wrote:the pineapple bushings are for s13s and s14s. the instructions telling you to leave the sleeves are for s14s only. for s13s you removed the sleeves
