extheflow wrote:i did own one...for over a year. it was my daily driver/beater. and the engine does not have to be up to operating temps for VTEC to engage. it takes about 20seconds. i don't know what the exact parameter is but from my personal experience with the car i owned .as long as it was warm enough to idle at the normal RPM then it was warm enough for vtec.
Yes, the engine does have to be at operating temp, that is the parameter Honda has set. I don't really care what you've owned.. it's factual information that I've verified for myself on numerous hondas. Anyways,I still don't believe a GSR/B20 setup will hit 10's with 230whp. There's no possible way even with slicks. I've been with Hondas for years and I've never seen a Honda under 275hp hit 10's in any hatchback from 2000+ pounds. I've never even seen a stock B20vtec setup make over 200whp either without headwork and better cams than a GSR/ITR/B16. But yea, you don't need to convince me.. I don't think I'd believe it without having worked on it myself and seen the miracle from the beginning. Not trying to be rude here sorry if I come off as an a$$.
