@waxednuggs - the same thing could be said about your LSx / LM7 swap idea though. VQ35 makes 287 hp, the LM7 V8 produces 295, and even the L33 only pumps 310hp. And the V8 will still need most of that other stuff too - rewiring, headers to fit into an S, driveshaft, mounts, exhaust, cutting and hammering, etc. Also heavier. And almost 2 more liters of displacement for only 20hp gains, VQ vs L33. Just sayin'.
$2500 give or take is pretty cheap for a VQ swap, or almost any JDM swap for that matter. That usually just buys the engine.
I always figured more ppl didn't do VQ35 swaps is cos VQ35's are tricky to come by for cheap. OP already has one. And a driveshaft he can use to fab one for the swap. And an ECU.
Here's 2 VQ35 into S chassis builds. The 2nd one is into an S12. According to that one, there are easier, and cheaper, ways than megasquirt. Like ways to use the oem ecu.
build-pics-of-92-240sx-coupe-t526066.html
nme-s12-build-thread-vq35de-s12-t492608.html
That being said, it is a pretty intensive swap compared to something like an SR or an RB from what I've seen. Read up on it, and see if it seems like something you'd be willing to tackle, I guess. As has been mentioned, its your car, you get to decide what you do with it.
Also remember the VQ35 can be supercharged
