video of why my car is a dill hole
ZOMG.SR20
Car: 1990 s13
http://www.youtube.com/watch?v=i-J5WxMzHCQ
btw thats full throttle and i let off the gas thats where it idles
now does everyone see why im pissed
ZOMG.SR20
Car: 1990 s13
no help in 240gen?
kc240guy
Car: gold s13 and a maxima
maf sensor or tps?
ZOMG.SR20
Car: 1990 s13
i just found a new OEM tps sensor in my bedroom so ima going to try that
SirSilvia
Car: Sold both my babies
ugh that's balls
Lost_In_Translation
Car: 1991 Nissan 240sx, stock with many problems.
Seems like a pretty big vacuum leak, and you should also check the tps , good luck
pj
Car: 95 s14
check the injectors dude.
ZOMG.SR20
Car: 1990 s13
injectors are fine as they are new
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Sounds like you're running on three cylinders.
ZOMG.SR20
Car: 1990 s13
that sound in the vid is my catback leaking at the CAT im too lazy to bolt it all the way up
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
sooooo, wheres the video of why you're a dill hole?
ZOMG.SR20
Car: 1990 s13
jdm ftl
Dill_XD
Car: 1990 240sx hatch
Heh, im Dill any luck with the tps?
ZOMG.SR20
Car: 1990 s13
nope didnt change any thing
pj
Car: 95 s14
new injectors, cool.wires going to injectors...causing the injector not to function. new or not.sounds like all yoru cylinders are not firing, sounds like a subaru...fiddle with the wires a bit while idleing...see if it changes it at all
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
sounds off, is it missing?
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
Your car is trying to speak to you. Allow me to translate, its' saying, "You got ."
j/k
Sorry for your misfortune dude. It's a 240sx which stands for "Big Problem Car that's better off at the bottom of the ocean" in a Wikipedia search. It's in the fine print but you need Max-Mega Pixel capabilities to decode it.
ZOMG.SR20
Car: 1990 s13
nope no missing
pj
Car: 95 s14
in reality it could be a couple things working together against you.but whatever you think, all 4 cylinders are not working.either its no gas or no spark. my car did the EXACT same as yours is doing now.check each plug/wire and injector individualy, if possible have a meter handy.youll have it back to normal in about an hour.
ZOMG.SR20
Car: 1990 s13
so just wiggle stuff?
pj
Car: 95 s14
ha smartass.look, the plugs and pigtails for injectors tend to corode somewhat over time, just slightly wiggle each with your finger, gently.see what she does...if no change then, have a volt meter to make sure the proper amount of current is coming/going , know what im saying?if this is still all good, pull each plug wire off individually, itll either make it worse or not change at all, the ones where it does not change are your problem area (the cylinders not firing). i mean, yeah im not there, im firing a lng shot here...but im willing to bet my cheeseburger and fries one of those injectors is not spraying and if its new it has to be the pigtail atatched to it.
ZOMG.SR20
Car: 1990 s13
i see will do tommorow
mattblancarte
Sounded to me like it was only running on 3...
My #6 was missing because of a loose injector clip. Got a new clip, fired up perfectly and hit the dyno for 394 whp.
Who knows, maybe you'll be that lucky.
ZOMG.SR20
Car: 1990 s13
well what do you know thew #4 fuel injector is dead
pj
Car: 95 s14
sweet, i keep my burger and fries. lol
ZOMG.SR20
Car: 1990 s13
now are 300zx TT fuel injectors the same as the SR one cause i can get one brand new for 32$
pj
Car: 95 s14
on that one i couldnt say man, but be sure to plug a good one from another cylinder in that spot to make sure its the plug itself...if a good one sprays get another, if the good one dies on that plug you wont need an injector because its just not getting a signal to spray.dunno if you did that already or not.check tech for injector compatibility info.goodluck, hope you get it goin
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
I got a box of 6 370cc sr injectors they all work most have new o rings installed $30 there all yours I run 740cc so i dont need them
ZOMG.SR20
Car: 1990 s13
email sent to [email protected]
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
ZOMG.SR20 wrote:now are 300zx TT fuel injectors the same as the SR one cause i can get one brand new for 32$
zerothread?id=59345
Yes, but I'd probably just take the 6 used ones for $30
