video of why my car is a dill hole
ZOMG.SR20
Car: 1990 s13
uhuh
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
ZOMG.SR20 wrote:email sent to [email protected]
Reply sent....please send any further emails to [email protected]
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
ZOMG.SR20 wrote:well what do you know thew #4 fuel injector is dead
Sweet! Problem found!
I'm stoked to see you fix this puppy and enjoy the power!
ZOMG.SR20
Car: 1990 s13
So I replaced all the injectors and now it runs
BUT!!!!
after hmmm about 15minutes it floods it self out the Fuel pressure is dead on at 38psi
I have a feeeling its the splicing of the o2 sensor into the chassis harness
Razi
Car: Moo
A bad O2 sensor snouldn't cause flooding of the engine.I drove around with a dead O2 sensor (wire rubbed and cut itself off on the EGR pipe), and my car never flooded itself.Still, if your wiring on the sensor is bad, you should fix it.
Does it still idle badly during the 15 minutes it's alive? How are your spark components?
slipknot555_666_69
Car: 97 nissan 240sx
try your maf and if that doesnt work try a newer ecu
ZOMG.SR20
Car: 1990 s13
Razi wrote:A bad O2 sensor snouldn't cause flooding of the engine.I drove around with a dead O2 sensor (wire rubbed and cut itself off on the EGR pipe), and my car never flooded itself.Still, if your wiring on the sensor is bad, you should fix it.
no it idles fine then gradually drop the idle and floods out
slipknot555_666_69
injector staying open bad wire somewhere or ecu messing up, kinda hard to tell
ZOMG.SR20
Car: 1990 s13
then when it dies I cant start it till the next day
also I can hear the injectors clicking open and shut
Razi
Car: Moo
Check your ECU coolant temp sensor.Mine had a loose connection and I couldn't start it until I waited for 1-2 hours.
ZOMG.SR20
Car: 1990 s13
ill have to check that I just bought this from autozone so it may be bad it has a 3 yr warranty any way
