UPDATE 7/23/14
I'm a little bored today and amazingly also with some open time, so I was able to take and transfer some crappy phone camera shots of a lot of things I haven't shown yet, with more to come when life allows me to do more. I was able to edit most of the cell phone shots to look decent enough, so here goes.
To get started, I've removed the coilovers and bits from the NA and after a LOT of cleanup, service and prep work beforehand, I recently finished installing them all into the TT.
Before shots
After all Powertrix parts are serviced, cleaned, new upgrade FUCA collars and debris boots installed, and in some cases paint/clearcoat.
RUCA connectors now have boots and paint for the spacers, the RUCA arms were so rough and pitted I lost chrome even with 600 grit wet paper but I really like and prefer the copper look with a clearcoat finish...
...the black marks are the pitting from rust
How she sits now with new 'spenders, as low as I ever go. The TT seems to sit lower and nicer than the NA did even before adjustments, for whatever reason
Closeups of the front bumper after repairs. It all still needs some tweaking and even repair work in spots and I need to swap out the messed up rubber trim from the NA headlight, but it is fairly presentable given the original damage
My "stable of steeds", now amazingly at three...
The Honda showing off her SEXY near-DPM color
And, the current state of the rear 1/4 panel waiting for me to ever get the mechanical work done...and waiting...
...for these parts to get installed
450 Tq ceramic Clutch, upgraded fork and chromoly pivot, throwout and rear seal.
My HICAS elimination kit- Z1 bar and the NA's PS reservoir painted w/ VHT gunmetal wheel paint, to avoid the TT res bypass headaches. Sorry for the crappy shot, dark back room...
And the Coup de Grace- the 530bb's, DP's, coolant hoses and couplers, gaskets and oil lines...
...plus the little stuff like O2's, knock sensor and upgrade harness, shifter rebuild kits and new oil sending unit. The Selin dual intake is installed, but no current pics until I get to my under the hood work
I still need to get 120K service parts at minimum and probably more as I am looking at other issues, so whenever that all gets done plus the body work, there's this package waiting patiently since 6/2013 with mud guards, and a new rear sticker set for my fiberglass Powertrix spoiler from the NA, but painted CRP.
Up to this point I have replaced the IACV unit with a good working one from Z1 along with all new connectors, replaced my CTS and temp gauge sending units and replaced all connectors, new spark plugs, replaced several incorrect NA PCV hoses I used with the correct TT ones, installed new silicone upper/lower coolant hoses as well as replaced the o-rings on the balance tube and refreshed it's paint along with the coilpack bodies, and also did some cleanup and rerouting of things along the way to make further work easier, and things look better.
Unfortunately she's still not running/idling right as she warms up and she still needs an alignment after the coilover install, so I think I need to go over the PTU harness again after the accident (haven't checked that old culprit yet...), as well as investigate a small drip oil leak at the PS rear of the engine that may be my theoretical rear seal leak AND my boost leak.
Looks like a plenum pull is in my future now as well, this all making me think that a complete overhaul or even rebuild may be in order to be fully satisfied with the upgrades and repair work I will be undertaking to save this car.
The NA is now fully figured into those plans as a parts source for her 1/4 panel and ANYTHING else I need, she's been a real sport about it...but it makes me sad even when I consider the $ and especially trouble she has saved me.
More to come when I get to things, although to be honest it may be quite some time because of a ton of sudden medical bills for me, and then sudden death of my brother which has changed a LOT of things.
Once I get to the PTU check and HICAS delete work planned next, I will get pics of the under the hood work.
