UPDATE-
So as I mentioned, I have replaced the previous arm rests I made with new ones- lower profile, a bit longer and with a wrap down the front side of the door panel.
Here's some pics and a description of what was done for anyone interested in taking on this job.
Tools/products used are:
A simple fine tooth bladed saber saw
Rough 80 grit sanding block
Utility razor knife and straight edge
Loctite high strength water/heat resistant contact adhesive
5 minute epoxy (DO USE!) and NOT wood glue for waterproof outdoor results
IPL panel adhesive (use this product before ANY other panel adhesive) for the same waterproof results
Gorilla Tape (strong enough hold and usually doesn't lose/transfer adhesive, cleans well if it does) to final hold/install arm rests, and a few quick key hidden foam padding holds
High density 3/8 inch foam and 1/8 inch wrapping foam
Some crappy thin excess cloth plus final outer cloth wrap
A pencil
Masking tape to hold gluing parts, NOT for final product!
Most is easily purchased at Lowes, Home Depot, etc. I have gotten my wrapping cloth and foam padding from work excess, but all can be purchased at a fabric shop.
Just a fun way to spend a couple of evenings with some simple hand tools, other than the power saber saw. BTW, the mdf is VERY soft and able to be cut easily with a hacksaw or other finer-toothed saw choice if you choose, and then rough sanded to shape with a block and 80 grit sandpaper.
Here's the cores after patterning/cutting/fitting (eyeball rough large sizing/ saber saw cut out, fine tune draw in, saw trimmed/sanded with block/80 grit to fit) to the door panels...
...1/4 inch mdf epoxied together with a compound joint for strength.
BTW, I used an approximately 5% angle as you can see to blend the front edge into the door panel better- while fitting you should see what I mean.
This can be sanded in roughly with the sanding block, and you can use masking tape to pull the joint together and stabilize it in perfect position while the epoxy dries.
Ease your outer edges and especially corners at least a little if not round them some as I've done here- it will make your finished outer edges feel softer, and you don't get "raised/bulging" edges and corners.
I went for a test fit at this point to ensure correctness.
Crap, too thick! I wanted MAYBE 1/2" tall max finished height, not 7/8+". Plus, the fronts just aren't wide enough...
So I then completely changed directions with the style of the arm rest, making all new ones and didn't photo those changes- basically I reversed direction from 1/2" thick top w/ 1/4" thick front to 1/2" front (thicker, and now also wider) and 1/4" (thinner) top- but the method used to create a solid front joint is still the same as pictured, but reversed- imagine the front edge 1/4" piece is instead the single 1/4" top piece to go about making the exact lap joint I used- front piece of the now two front pieces is wider to cap the front, with the two pieces glued and clamped or taped together- this joint has the best strength for the job.
Fuzzy shot of one rest with high density foam top surface, other then with the following 1/8 inch foam wrap before (unpictured) a thin, "any old cloth" wrap to hold the overall shape better, then finally the outer wrap- both still to come...use contact spray sparingly as possible to avoid incorrect drying but still ensure each level is bonded tightly, or things will begin to come loose. Be SURE to follow application directions, and mask against overspray where you are working! Also a heads up that padding gaps/lumps will transfer badly on the final surface so keep that in mind, and is a reason (smoothness) for the crappy cloth layer wrap I used (past experience here) before the final outer layer wrap.
Trim your padding carefully as you go and note how things bunch up, any fastening difficulties with padding buildup, and where your cut/fit difficulties will lie with the final layer...this is your practice for the final layer! BTW, I have 6 total sets now so don't feel bad if you mess up, or change your mind on something...and I will say this is not the easiest wrapping job for sure.
...and now both ready for final wrap. Sorry, forgot to take wrapping shots as I was in a hurry (3rd set...)
And next day, here are the finished items taped in place as the IPL dries. Big blobs or round "donuts" (not TOO big, be mindful of adhesive oozing out edges) of IPL work best placed in 4 spots near corners, plus some small dabs at the front edge for stability, then Gorilla Tape in place being careful to not rub holding tape in TOO hard (avoiding possible adhesive transfer to your door panel), just enough to hold the rest firmly in place. The tape holds very well and the IPL product is an excellent industrial-grade adhesive that gets very hard, but stays SLIGHTLY pliable...we'll see if it's up to this task while also bridging gaps. Using a very sticky tape such as the Gorilla tape avoids the inevitable stretch and grip loss masking tape has- this has to be held firmly in place for 1 hour+, and cure for another 2-3 minimal for usable strength- and 24 for final strength.
Note the dimension changes to the rests, and mounting holes in the tops that disappeared.
Again, the fronts are now 1/4" thicker and top 1/4" thinner for the lower profile I wanted, plus the glue fastening method change. Still a tad thicker than I wanted at about 5/8" above the "deck height" of the regular door panel arm rest ledge, but hey- I can always rip 'em out and try again with different products if my personal picky-ness says so.
Everything needs a cleaning from the mdf dust and I need to make some cloth "tube" finishers for the gaps at the ends plus further detailing, but easily done next weekend after everything is well dried and tested for re-glue/another Z repair project/Total Redo. All possible!
Up next is perhaps adding some key red interior bits from the NA while fixing the rear interior situation trying to finalize the interior somewhat for now, and adding the front wheel spacers, plus a few new ZSpec bits coming in the mail soon...stay tuned!
