So as the worm turns, and things get done...the Home Improvement project moves forward as one window almost done, one to go.
Of COURSE, time was found for Z fun.
I had an itch that after finding no cure on the site I've been watching, Z1 scratched in two days- ZSpec '94+ chromed J30 throttle spring covers and SS fasteners + finishers...for my '93!
Like that little detail was gonna bother me for $40, I ordered them with no plan in mind and had them on and looking great in my 3 extra hours I found Saturday!
PS was easy peasy, dry fit as I wanted and mark, simple drill/tap into the useless coil hold down lump for the "inside" hole and a dead fastener/nut setup in the "outside" unused end- and Voila, perfecto!
Unfortunately, sitting as close as they do to the coil packs I think I need to add the red finishers there as well now...<sigh>
DS was far more of a problem, with only the small waste stud on the side of the throttle body to work with, and the plenum offset as well. I fabbed a bracket that failed because it couldn't mount as needed and also provide inside-to-plenum coverage, so running out of time and without proper materials, I made a flat backing bracket to fill to the plenum as needed and bolted it to the cover, then epoxied it in three places in the correct position. I was very happy that both positions I found lined up perfectly with the same coverage and general positions when viewing as a whole.
It sits solid on the throttle body stud and is very solid with the backer glued along the side to the plenum (JUST touching the DS cam cover) even before 100% epoxy strength, and if not and it fails, I'll figure out a correct bracket then. I could get the small angle aluminum I need from work but didn't want to wait.
Maybe my favorite dress up mod yet!
So here's the overall view now with current work done...New:
Versus old:
There still are a few items left to play with, like ZSpec SS manifold bolts/finishers.
I also contacted Chris at ZSpec for some of the longer fender bolts and cap screws in a mixed 25 pc. bag and he was back to me that same day and happy to oblige (GREAT guy and company, customer service) so these all will go on when Z fun time allows, which also now includes a paint refresh of the mirrors and window trims to match the cowls.
Thanks Chris for another quality product!
Stay tuned for more...
