UPDATE-
So the CSF radiator arrived last week and the IACV was ready and waiting, time to get to work. I REALLY want to drive her and also have everything working correctly!
I got started Friday but forgot my camera, so here's an update for Friday first, then today.
I got the rad out and IACV in, and a few other small things done before calling it quits after 8 hours.
Most of my ZSpec fasteners and finishers now installed
Intake hardpipes now finished most of the way down, rad hardpipes got scuffed and a clearcoat shot of VHT.
I decided to modify the horrible PCV tube removing the bracket for the balance tube and shaving it some...it installs SOOOO much easier now.
So today as I got started, a few small details more while she was open up front. The CAS got shot the dark bronze color, and some ZSpec bling.
So Saturday the rad was dried for 24+ hours as well as the shroud.
The shroud fastened properly on the top with ZSpec SS fender fasteners...
But I had to use a flanged nut to catch the very edge of the bottom of the rad because it surprisingly had no provisions nor size for bottom holes and mount points.
It also had no provisions for the ultra-important coolant hose holder, so I mocked it up and drilled a hole and was able to get it where it was needed.
And finally, ready to install!
Took just a little massaging but it went right in easier than the original, and fit nearly perfectly. The shroud just doesn't quite meet the same but it is well hidden by my rubber strip on top and the unpictured stock air guide that took some massaging to get installed on the narrower top rail. I also had to set aside the crappy new Nissan radiator cap I bought and use my old one, because the new one was so sharp it wouldn't work smoothly and would get jammed closed and was scraping off PCV each time you used it.
And the final pic before I went driving!
She was a little spastic for a bit but settled down fairly well, idle was good and no IACV crap and I ran the heater high the whole way. Got home and cooled her down while cleaning up, filled about 2 more pints and she was happy as possible right now I think. Drove home well, so she's ready for a few days driving to work or more and then back to Doug for (hopefully) final tune tweaking.
The Jspec is also now on it's way so all of my body parts are in the works, except the rear 1/4 panel. I also have contacted my body guy Charlie and we are set to have her in his hands this late summer or fall, probably September, and he can handle getting a useable 1/4 panel. He feels he can repair the rest which is awesome news. My hope is to have her 90+% done by the start of next year, with final details and tuning/tweaking hopefully the only things left other than enjoying her!
So this may be it for awhile unless as I hope I get some access to her during body repairs, if not even being able to get my hands dirty a little and learn about the whole body panel replacement process.
