240lookis »
https://forums.nicoclub.com/240lookis-u98510.html
Thu Dec 11, 2008 8:10 pm
for the paint prep, i did the following:-sand everything down with a lowis grit sandpaper (maybe 150) with an industrial electric sander-washed the car down-masked everything off with tape/newspaper-sand everything down once again with a highe grit (do this a lot)-run over everything with a tack cloth to get it super clean.-covered the whole car with a layer of paint-let it dry-sand it down again, but only t scuff it up, i think i used 500 grit-thoroughly clean it wiht tack cloth again-go over entire body a couple times with rattle can
i had no previous experience with this. at first i applying the paint, but then i got the hang of it.
i tried using clear coat, but i just screwed up. you cant see it in the pics, but there are some horizontal lines on the hood from the clear coat. also, i used semigloss paint.
