240DrpTop »
https://forums.nicoclub.com/240drptop-u75116.html
Sat Oct 20, 2007 11:12 pm
JB82,I've spent 2 hrs. yesterday cleaning connections and checking for resistance.Still produces a nice click every now and then.I think my next move is a genuine Nissan starter.I called the dealer on Friday.$238.00plus $50 core charge if I didnt have an origanal OEM core to return,total 283.00 ouch! Hope that cable works out for you.Also if you have a voltage meter,you can test between the positive cable and the small black wire directly at the starter selenoid. I would do this with the pos.cable connected to the battery,and disconnected at the starter.Have a friend turn the ignition switch,while you hold the leads on the pos cable(the end that connects to the starter and the selenoid wire).Should have 12 volts.First make sure that there is 12 volts at the battery. I would do this test numerous times being that,this seems to be an inconsistant problem.If you have12V every time,I would replace the starter w/ Original equip.If this this dosen't work you can always sell your car and buy a Camero.Just kidding!Good luck with that.
Modified by 240DrpTop at 2:28 AM 10/21/2007
Modified by 240DrpTop at 2:33 AM 10/21/2007
Modified by 240DrpTop at 2:34 AM 10/21/2007
Modified by 240DrpTop at 2:36 AM 10/21/2007
