that was me witht the first starter 20 min. after work sitting in the parking lot.jamesblonde82 wrote:i was living with it too it wasnt bugging me much....but then it got worse and i was clicking for 20 mins or so b4 it would start up. that would be helluva situation in an emergency.
Hand crank that sun of a witch! FTW!krash14 wrote:as you walk on the sidewalk you get a call on your cell phone: "come quick! i need some help fast! Some people are chasing me in a car, im on foot! im right around the corner!" You think, "I can pick you up in my vert!" you run to your car with your female sidekick . you smoothly jump the door on the vert (the top is down) and land comfortably in the drivers seat, you female sidekick does the same. you put the key in the ignition AND.... click...click...click....click...click...click... your female sidekick opens the door, gets out the car, gives you a look of pity, and walks away. your friend gets captured by a bunch of ricers in a "Type R toyota".
http://www.nicoclub.com/articles.php?id=160219jamesblonde82 wrote:do the ignition coils have anything to do with the starter? maybe you mean the selenoid...which comes with a new starter, so that's not it.
For the negative cable you could just get some 4 gauge or lower wire from home depot and some ring terminals, maybe, 10-12 bucks? Also, for better grounding, add replace the braded wire in the back left of the engine that grounds engine -> firewall with 4 or lower gauge wire, too. Also adding more grounds from the engine -> chassis might help.jamesblonde82 wrote:neg was $62.63 pos was $118.16
You can get a "made for the car" one from rockauto for $15. I gotta check the condition of the terminal in the middle of that cable on my car. Hopefully, I can wire brush it rather than replace it.jamesblonde82 wrote:as far as the neg cable i could have gotten away without spending 60 bucks, but it was designed for the car so what the heck.
ahh no don't tell me that...do you have a link to it? its not on the car yet, so i can take it back.ishkabibble wrote:
Nah i've tried that and it didn't work for me, but mine's wierd. I've got remote start and every morning I start it to let it warm up, starts on the first try. Everywhere else, like school, work, store... I'll remote start, and if i'm lucky it'll be on if not I get to the car click it a few times then finally vromm. I can't figure out the problem either on it I just live with it.krash14 wrote:try this: put the key in and turn it all the way, if it clicks, still hold it there and it will start. thats what mine has been doing latley. it should sound like, CLICK......vroom. tell me if it works.
