I have considered a stock SR. Its too much time, money and effort. I would be doing the swap myself and but its still $2000-$2500 just to get it running in a usdm s13. Also you have to hunt for parts from different vehicles. I just thought that ka-t would be nice because I like the ka and it would be cheaper. I would like to spend less than $1500, but if that is impossible than I guess I'll just stay n/a.180fan wrote:have you considered a stock sr?
I am looking forward to it. That would be awesome if you could show me a video of your stuff. Also show me how much it puts out and the price it cost you.VeloceDrift wrote:I hear good things from the stock ignition and fuel system so hopefully its goin to be ok to run 7psi without much mods. ill let you know how it goes.
I am looking forward to it. post some pic's toVeloceDrift wrote:my car should be done this weekend and im turboing my KADE. im using a stock SR turbo. i got an intercooler kit online for fairly cheap that bolts right up and im having a manifold made. i hear good things from the stock ignition and fuel system so hopefully its goin to be ok to run 7psi without much mods. ill let you know how it goes.
yeah thats why i am doin the KA and over all its a way stronger block and a lot easier to get parts for if i blow it up;) ill be postin some pics and hopefully some numbers as soon as its done.Vernal wrote:I have considered a stock SR. Its too much time, money and effort. I would be doing the swap myself and but its still $2000-$2500 just to get it running in a usdm s13.
Thats exactly why Im doing about KA-T. Im set on KA-T but Im just not sure when. I was wondering how much its cost you to do your turbo kit you made.VeloceDrift wrote:yeah thats why i am doin the KA and over all its a way stronger block and a lot easier to get parts for if i blow it up;) ill be postin some pics and hopefully some numbers as soon as its done.
An intercooler is not an intercool. Its an intercooler. You are talking about the name right? Since I obviously have never put a turbo kit on my car, I am not sure what the price range was. It looks like its going to be $1000-$1500, hopefully less. I was just wondering what is wrong with ebay stuff? I heard that the turbos are bad, but what is wrong with ebay manifolds, downpipes, etc. Pretty much everything except the turbo. Well good luck with your kit I hope to see some pics and videos soon.VeloceDrift wrote:well i got a intercooler kit on ebay for a couple hundred(an intercooler is an intercool right?) and it came with all bolt up piping. I also had a blown SR in my garage so i got the turbo off that(freebie value) and around 700 for the guy at the shop i go to to build the manifold, tap the oil lines and build a down pipe. just stuff that i dont have the tools to do at my house so over all its not to bad.
Yeah I'll do some research. I'll probably end up getting just a smaller turbo and use a smic.VeloceDrift wrote:im not sure if their is a manifold that will bolt directly up to the SR turbo. you will have to do some research for that. if you want to do a side mount then you might as well go with the stock SR side mount intercooler. the nice thing is it came off a 240sx so it will go on one very easy.
No what?pigiepigie wrote:no there is not sorry , for the bad news my freind.
So is he WDRacing on here? Anyway like I said before SR is too much time, money and effort. With a KA-T I can just go to autozone and ask him for parts from a 1993 240sx and everything works out with no confusion. Anyway everybody goes SR so the KA-T people are the different ones.redtop91 wrote:225whp can be had easily for under 1k. You should email WDRacing (Brian) he can hook you up. You should go SR though
Amen brotha. That is exactly what Im talking about. In the words of Borat "High Five!"booboo wrote:do not go sr i like the ka too and i have a 1991sx
Many people are unaware about the capabilities of the KA24DE. Yes, it is a truck engine! And yes almost every turbo 240sx out on the street is SR20 powered. Many of us that do not have a lot of money to put into our cars, but want something strong and fast, should go with the KA. Also, the SR20 is an imported engine, and if something breaks, one will have to spend a lot of money to get the parts, but the KA24 came in all the 240sx, some Altimas, some Xterra and Frontier, meaning that there is tons of parts out there for them. The SR20DE nonturbo has 140 hp and 132ft. lbs. torque. The KA24DE has 155 hp and 160ft. lbs. torque. Compare the two and the KA24DE has very strong internals and strong base because of its truck root. It is true that the powerband on the SR20 is wider, but the KA24 cannot be ruled out. If you buy a 240sx, 9 out of 10 times if will have a KA24 in it. Also the KA24DE has more displacement, iron block and is cheaper than the SR20. To get a good SR20DE on your car one will have to spend at least $2000 on the engine with decent miles, then all the wiring to make it work with the 240, transmission, you might have to get a turbo if the SR20 is not a turbo, and all of its components. That will be a total of about $4000. All this money to get 220hp out of the SR20DE-T. If one puts $4000 on the KA24DE and turbo, it will be a hell of a street car. and will be spanking the SR20DE-T any day.
Modified by booboo at 8:27 PM 3/19/2007
No actually. They are both just as played out. This is the reason why most people don't go SR. There is plenty of misinformation in this thread. Like SR parts not being attainable. Most parts are exchangeable with the B13 Sentra and you can go to Autozone to buy those.Vernal wrote:KA-T people are the different ones.
Putting a DE into a 240 = failure. The iron block on the KA makes no difference in any realistic boost levels. KA's will require rebuilds for 99% of the turbocharging. The misinfo goes on and on. Choose what you want but at least be informed about it and ask people who know what they are talking about.booboo wrote:To get a good SR20DEModified by booboo at 8:27 PM 3/19/2007
Vernal wrote:Sounds cool man. I want to boost around the 7-10 psi range. I just don't want to have to upgrade my fuel system or anything else. I really just want a plug n play kind of thing.
-I believe what was trying to be said was that there is no kit or setup that will get you boosting safely in the 7-10# range without upgrading your fuel system. The first thing you want to consider is fuel, otherwise ::ping p-ping ping:: there goes your engine.And it's not like its difficult1) Walbro fuel pump=1hr install time, just wires in where the stocker was.2) 370cc Sr injectors, they fit right into the stock fuel rail <1hr install time...just be careful and lube up the o-rings real good so they don't tear on install. 3) Safc to compensate for the larger injectors. Done, this is the essence of "plug and play"Vernal wrote:No what?
Nothing major ever breaks on mild boost SR's so special order parts almost never need to be ordered. Mild boost KA's mostly will at least require new piston rings which equates to motor disassembly and added cost and effort. Above mild boost, most KA's will require forged internals, yet another disassembly and added cost.Vernal wrote:Not everything is interchangable with a sentra se-r.
Maybe so but just because you are mildly boosting a KA does not mean you are failure exempt. SR's almost always are safe at mild, even high boost levels. SR's are sleeved as well so the iron block thing? Null and void.Vernal wrote:There is no possible way that a SR is cheaper than a KA-T if it is going to be boosted mildly.
Nothing wrong with that. You have just ruled out the SR on obviously incorrect info. Like I mentioned before at least be informed about something before ruling it out.Vernal wrote:Say what you will but I was just trying to get advice on the whole KA-T setup.
Its not incorrect info. The SR is more expensive thats why I ruled it out. That is 100% true. It is not automatic that I need piston rings and forged internals to mildly boost my KA. That depends on the mileage and condition of the motor. My motor is in great condition and has less than 90k miles.redtop91 wrote:Nothing wrong with that. You have just ruled out the SR on obviously incorrect info. Like I mentioned before at least be informed about something before ruling it out.
