Vernal wrote:After I fix the leak I have I want to turbo my stock KADE. I dont want 500hp. I just want a casual hp gain (Around the 250ish area). Is there any KADE turbo kits that you dont have to upgrade your fuel pump, fuel rail, etc. Just a bolt on kit that is reliable and wont put a beating on my engine. I want something like the stock s13 SR has. Small turbo that puts out some hp while being reliable.
Turbocharging a KA motor is lots of fun. I made around 320whp at 12 psi with my setup last summer. I had a t3/t4 garrett turbo, walbro 255lph fuel pump, hks 555cc injectors, AEM Fuel pressure regulator, APexi super air flow converter (safc) and the APexi actuator valve controller type-r (AVC-R), 24" X 12" X 3" Intercooler, 38mm Wastegate, HKS SSQV Blowoff valve, ebay exhaust manifold (with lots of ceramic coating and heat wrap ), HKS Turbo Timer , autometer gauges, etc.--later i switched to the xcessivemotorsports manifold because the ebay ones (i went through 3 of 'em ) cracked like little bishez!320whp lasting almost 9 months is great considering that i never modified/opened the motor, not even a head gasket!! hahah
There are a few KA-T turbokits out there, but they are much more expensive than just doing an SR swap..The only downside that I noticed with turbocharging the KA motor are the piston rings' high tendency to get fried and frequently burning oil (usually after highway runs) Although the KA-T was lots of fun, it was no cheap project. It nearly cost $7,000 before it's demise (threw a rod through my block) this spring.
If i were you, I would either go the cheap way and do an SR swap (200-220whp), or go for the gold and do a KA-T setup (155+whp), it has proven both rewarding and funn as hell!! and btw, there's nothing like the KA's torque
Good luck on whatever you decide to do.P.S. If you don't do any fuel upgrades to a KA-T (hence intentionally running lean, which is extremely dumb to do), you'd better kiss your motor goodbye because it won't last a couple of months.
Modified by Abdo at 6:07 PM 3/30/2007
