Chezedik wrote:...but what would you suggest is the effective limit of the KA in terms of boost (reliable). I get back to this part because if I am going to have to make some serious boost to make my power, then I need to factor that into my plan. So, let me put this another way, what kind of outputs have others seen when they stuck to the stock block, and assuming other mods. Also, as far as engine management, I was thinking of getting my chip burned for larger injectors but not doing anything with the timing, or using an FMU.
The stock KA block has been shown to handle more than 1 bar of boost without problems (14.7 psi +), but in all honesty if you want something that will be reliable I would personally stick to 10psi or under. ...And this is assuming all your tuning is there.
You say you are looking to make what? 250 rwhp? You dont need "serious boost" for that kind of power. 10 psi-ish should get you well within that range or more, again assuming your tuning is there.
Why would you get a chip burned and not do anything with timing? I dont understand that, timing is pretty much THE most important part of tuning. Power rises and falls, EGTs go up and down with just a few degrees of timing here and there. To do this right, you HAVE to have correct timing- not only for saftey, but for maximum power. ...At any boost level.
As far as picking out the right turbo for your application, I think you are on the right track. I dont see why you decided to graph out the compressor maps the way you did, but there is some logic to them. Definitely check out the stickied thread with all the other compressor maps people have already completed and posted for you to see. 10 psi is a very common pressure range, you should have no problem finding turbos already graphed out for that range along with pros + cons. Keep in mind though that these compressor maps that we draw are VERY rough approximations of real world conditions. Volumetric efficiency is not static, and it differs not only between engines of the same type, but along the RPM range as well. Dont concern yourself with extreme detail on these things, all you really need is to find a compressor that will give you the fattest general area of efficiency possible-- no need to get into too much detail with it because they are simply not that accurate the way we are calculating things.
Youre asing good questions though man. Keep at it, I like seeing people who want to get this involved in their build up.
