DRIFTEADOR wrote:less inertial=less load, and less load=slower spool. with a smaller turbo you probably wouldn't notice but for those with larger turbos, don't you spool earlier in 4th gear compared to 1st?
Don't hate on my technical drawing.Chezedik wrote:I don't mean to alarm you, but I think your 'mad tight' SR has turned into some sort of pirate vampire, so be careful. I have pretty much decided that I will be buying the Enthalapy programmed ECU available from Boost Designs. I have decided on this because apparently, he could talk a kia into running 9s. If you don't believe me, check the Secret Services 240sx, apparently, he tuned the ecu, and it's balls out with a stock block. Then I am going to go with the turbo setup on ebay from ssautochrome, which is a gt28rs clone of sorts. Kind of like disco potato, but a little slower spool up, but about 1300 less for the kit, so you do the math. Anyway, from there it has already been done by someone else, and they have figured it out, so seriously, look into that ECU. Let's see, for the same price I could have that, or Jim Wolf, let's see... a guy who boosted a stock block KA to almost 400hp, or MSD injectors and an overly complicated fuel system setup. So, in conclusion, Enthalapy good, me boost muy mas because he figured it out for me.
IHI RBH25 < SR T25s13sr20chris wrote:still looking for junkyard turbos? the ford probe has a pretty good turbo. also, there are a few old chrysler products with decent t3's.
You can save yourself alot of hassle by just not worrying about compressor maps.Chezedik wrote:Yes, t28 is like t25, but smaller. You are supposed to be able to port out the t25 to the 28 and use the different wheel, and I guess it is supposed to be somehow cheaper.
for real? thats what i get for listening to internet claims. thats why i like my garrett stuff. you can usually get a compressor map and sometimes a turbine map. oh, but you wont find either for t22, t25, or t28. so sorry. wish i could but every garrett engineer i spoke with said its not going to be released.Nismo_Freak wrote:
IHI RBH25 < SR T25
i believe the earlier ones had a t3 60 trim and the later ones had a t25. the real early t3 units were not watercooled.Chezedik wrote:bump again, what turbo does the z31 use?
I build about 5psi in 1st... And thats right when I loose grip. If I had an LSD and less camber I bet I could make 10psi. (And this is with a fadinza flywheel)DRIFTEADOR wrote:mine did too but boost came in later. wd, try it in neutral. all i'm saying is a greater load makes for faster spool. I dont know how much a lightened fw would affect it
