Ohh thanks i will check that this weekend and let you know. I can't sleep for this...
Ok, i gonna brief some facts:
- When i purchase it the car had a modified CAS and the turbo had the westgate actuator open
so drive it nearly N/A, i paid cheap so know this could happen...
(notice the cas in the picture 1 and 2 )
Pic 1
Auto_020 por
Luchitosan, en Flickr
Pic 2
DSCN9075 por
(not ask for the giraffe...)
- then connect the westgate on to the garrett but runs like s***.
- then blow the Gb2525 oem
- put a Master power 802306
- And this happen ...
Pic 3
DSCN0038 por
- so rebuid the engine, the ecu is all stock (never chipped), new CAS (pic 4), timing, ect....
Pic 4
DSC01581 por
Pic 5
DSC02811 por
Pic 6 (Master power turbo installed)
DSC02815 por
this is the line you want to test
- Runs very well but...then the glowing problem, more soft, not like the picture 3...
i can paste a new one if you want...
- Then up the FPR from 36 to 40 lbs, and was better (less glowing even)
- But is all working stock except forged pistons and cometic hg,
Some doubts:
Can this new turbo is .63 turbine /.42 compresor... be too small for this upgrade?
Can the ecu retard the timming for knocking?
cause the Knock Sensor cables was cut it soI join the cables (thanks Float) to make it work.
knock-sensor-cut-wire-t499639.html
