Good News Problem Solved !
boost_boy wrote:Problem identified. Your engine is running lean; very lean. It is not your turbo or manifold or a restricted exhaust. Either your injectors are clogged or your pump is insufficient or performing poorly. Definitely a fueling issue and I can tell by looking at the exhaust ports of your turbo manifold.
Fuel issue YES, but not lean, thats why don´t blow the engine
The thing is the FPR GAUGE IS CLOGGED (fabrication failure or insuficient scale to 50 psi)
shows 36 psi but god knows how much fuel where deliver ( but much more than need it)
The gauge
DSC02840 por
Luchitosan, en Flickr
The symptoms:
- Some cilynder start to fail at idle (now in know that began to foul spark plugs)
- Raw gasoline smell from exhaust
- When advance the timming works better and runs like hell from 4k rpm
- Spending more gas
- AFR gauge shows
17 to
19,5 at idle (lean) (cause the excesive gas cooled the O2 Sensor)
- Propp-pouuf sounds from the exhaust when drop the acelerate pedal.
- Turn fully open or closed the FPR needle hardly varied
I know that sound stupid now but never imagine the gauge could fail
be amateur and a $40 gauge can ruin the engine.
Solution buy a correct new gauge set up the FRP and READY !
Now cruises perfect in exhaust and manifold shows 14 or 15 AFR, thats ok i guess for stock ECU.
Thanks you guys, i can post a video of the car running i'm happy again !
Luchitosan
