True Pig Build
allmotoref
bro what wheels are u useing i like them alot
ritz
Car: 1992 Nissan 240sx Hatchback SE
i also say go with the blue. but low91240sx has a point, i havent seen a brown 240sx as well.
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
yeah I think i will go blue but it is a toss up between the two oh well i guess it will be a suprise when its done. the wheels are sportmax 002 16/8 with 15 offset i think the company changed its name to xxr.
ritz
excellent choice sir.
martins_240sx
okay so if you guys didnt see my new post I heard my car run and it is perfect....except on deceleration. when you rev it it is fine but when it decels it sounds like the timing chain is rattling, but it seems tight. so i have no idea...anybody with insight is welcome to help
bourngooy88
Car: 1999 honda passport
NICE BUILD!
all your car needs now is a good wash! lol that thing is dirty! i guess that is the point of being a pig build :D
scooz14
Car: 1989 240sx hatch
my timing chain rattles on decel too. i just changed everything out though. let me know what fixes it if you find out and i will do the same
martins_240sx
well the piggy is swapping to a new piggy...It is going to be my new 2 tone piggy coupe...will show pictures later
martins_240sx
my new one it has tein superdrift coilovers and fno1rc or something rims with five lug swap ..... soon to be the new true pig
ritz
nice ride chief.
pArAdOxsqUArE
nice.... i have the same motor.. ahaha well before you swapped it. hopefully i sell my civic and use that money torwards my swap.
martins_240sx
I didnt swap......
martins_240sx
well i got both sets of sway bars today...ill post more pics on the installoh and for those who didnt know my hatch is going to be ls1 powered after my deployment....the coupe will take the kat off the hatches hands
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
your coupe is beautiful
good luck with the build
wildrifter
Car: '89 240sx Hatch w/ S14 SR20 swap
Hey, I'm new to posting on the forums, but I've been watching your build and it looks awesome. Me and my bro are working on our 240 at home and it's been a huge project too.
And you're stationed at Camp Pendelton? My Aunt and Uncle were posted there not too long ago...I've visited a few times, and I love that area. Anyways, good luck on the build!
s14derrick
Car: 1995 nissan 240sx
martins_240sx wrote:my new one it has tein superdrift coilovers and fno1rc or something rims with five lug swap ..... soon to be the new true pig
that thing is way sexy
martins_240sx
thank you all of you and yes im stationed at pendleton
willywong
Car: 1990 RPS13
dude awesome clean build! i like to see when people do builds right
martins_240sx
Well I just went to check out the damages that they did to my car. they crushed my test pipe and broke a hanger on my exhaust...they are making me a new test pipe and rewelding the hanger.but on a side note I heard the engine run again and since they have been running it off and on the timing chain noise is no more. it was beasty, no exhaust...they said by next week I can have it back working.
the delays.....emance. sent me inop ecu, sent it back and going on more than 2 months without a return money/or productand the aem ems, back order....
ritz
dam man, you'll get your stuff soon enough though, and it'll be looking real nice once again.
wildrifter
Hey Martins, that's sick that you're at Camp Pendelton...hope you're likin it. Anyways, I wanted to know what kind of roll cage you have installed? Did you buy it or make it yourself? I've been looking for one that I don't have to cut up my dash to put in...Thanks.
martins_240sx
its a cusco 6 point cage....hope you dont think you will be able to use on the track that much though. you get more hassle than without it. its because of what its made of. but it did stiffen the car up nice and tight.
Fractur3
Car: 04 built 35r STi
what did you use to paint your valve cover and intake mani?
martins_240sx
just spray paint...high temp and clear coat spray paint
martins_240sx
well today I installed my godspeed sway bars. I like the difference but intallation, for the front, sucks d!ck...and the bushings that come with it suck. you will see when I post pictures... I also changed my rear wheel bearings. all of this on my coupe. my hatch will be back soon since they are changing my ems to one without the wideband and then ordering it seperate since they are back order for the set but seperatly they are available so look out for my wheel bearing write up, with pics. maybe ill get a custom title....Nico's Pig Farmer...
martins_240sx
New pic of me and the hatchsway bars...notice the gap in the bushingsI dont even want to talk about the fitment in the front....but overall big improvment....now into the wheel bearings write up......
1. first you must take off the wheels.2. Now remove the caliper and then slide off the rotor.3. remove the cotter pin on the hub and the lock collar then with a impact remove the 36mm nut on the shaft.4. there are 4 bolts on the rear of the hub. rotate the axles so that you can remove them.5. once these are removed, grab the spindle and shake it loose off the splines.6. the tuff part is pressing the bearings off the spindle. I used a hydralic press to do it. the only pain was that the inside race of the bearing wouldnt come off so I had to cut it off.7. now press it all back together. make sure it is all the way to the stop of the spindle.8. reinstall it back to the hub. those 4 bolts.9. Now the spindle nut must be torqued down to at least 206 ftlbs and no more than 276 ftlbs. after that is down add the lock collar and install a NEW cotter pin.10. reinstall rotor and caliper and wheel.
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
Whats up devil. Your build looks great. When you scheduled to deploy? I am headed out in jun or july, for the 3rd time in 7 years. Deployments are good for 1 thing, Making that money for toys!!! I am planning a Rb25 swap when I get back. I already got my project car sitting in the garage. Good luck seems like u are doing it right!
martins_240sx
sounds good "ma-ruit"....yeah Im leaving jan. with clb13 ''meu''
1995240sxSE
havent heard that one b4 ma ruit thats a good one. Take it easy over there!
martins_240sx
yeah its one of my favs....not really a recruit, not yet a marine.
