Transmission leak
canoeboy1
Car: 96 Q45
I have a 96 Q with about 102,000. Transmission began to leak some time ago. has been diagnosed to be leaking from a sensor on the TOP DRIVER SIDE of the transmission.
Has anyone ever replaced this sensor. The local trans shop wants to drop the whole trans to get to it.
I wonder if you could cut a hole in the tunnel and replace from the inside the cabin?
The transmission is fine as long as you keep it filled.
Any thoughts?
Thanks,
Paul
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Do a search on turbine sensor in the Infiniti Online Mechanic Forum.
Get the parts from Joe, including the rear main engine seal as you will be dropping the transmission.
Squeefoo has done the tunnel trepanation.
Welcome aboard!
96Qowner
Car: 1996 Q45
Squeefoo managed to get at his by boring a hole in his transmission tunnel, next to the gas pedal, heheh.
zerothread?id=116355
zerothread?id=114647
(FarFetched has/had a Y33 - squeefoo's was a '90 G50)
Otherwise, someone's gonna have to drop the transmission a few inches to get at it.
canoeboy1
Car: 96 Q45
Problem fixed.
I took the pages I printed off the site to my Transmission guy and he drilled the hole in the tunnel. Total cost with parts $495. He had told me it would cost $1,000 just to drop the trans.
Now that the new Turbine sensor is in place the car runs like new. The car use to stall at stops and no longer does. It feels like the HP has increase by 20%. The whole car runs smoother.
That sensor must have a major impact on who the whole drive line runs.
Big thanks to all of you.
Paul
Q45tech
He had told me it would cost $1,000 just to drop the trans.We charge 7 hours or $525 in ATL plus parts.
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
That's the thing that kind of sucks with the Q is putting things in the most hard arse places to get to. Just look as something as simple as an oil change and the smart people at Infiniti decide to put the oil filter in that difficult spot. The oil change guy curse me when I come rolling in with the Q.
