I've installed the head with swapping over the inlet manifold to the original one torqued it down & got new cams.
When I started it up it just ran over faster than it shoudve
I set the timing with a new gates tbelt kit with new idler n tensioner bit the two cam marks weren't exactly on the timing marks they were both close but about 2/3 mm above the backplate marks
When.I counted thr cogs between the cams they were 39cogs including both dotted cogs& thr crank to cam cogs were 48 including thr dotted ones
It's not exactly firing now seems as it wanys to but can't
The shafts may need timing again making the belt to align properly but with this gates belt it makes the cams turn everytime I try & pit on the belt
But could my.timing be off by mm's as all the cogs seem to be in place
This is hopefully the only thing left now then il get a clip on with it in biz
