float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Aug 01, 2015 5:11 am
The oil pressure should be greater than 11psi at idle, and between 51-60psi @ 3K RPM.
The rods, like the connecting rods. There's a bearing where the rod connects to the crankshaft. When the clearance on that bearing becomes too great, generally due to wear, it often makes a noise similar to what you're describing. I suspect the noise isn't in the gearbox, but the engine.
