s13drifter88 wrote:
-1 and -2*? i would be ashamed if i was rolling -2* camber... and -5.5 in the front, what the faqk!?!?!?!?!?!? what'd u do, cut ur springs down to 1 coil!?!?!?!? does suspension geometry mean anything to u? handling? drivability? performance? -1* gives sporty handling but after that it becomes "darty" eats tires to hell and back. I used to be a Master alignment and suspension tech for Firestone and still hold me ASE's.
this is a joke right? i know you got to be joking with me when you said this...
im on coilovers, tein HE coilovers, but that has nothing to do with my alignment specs because every arm on my car can be adjusted! its not just like that cause i cant change it i can put it to pretty much anything that isnt restricted physically by the wheel or by the arm, my set up works for me
i run so much front camber because i have an extended LCA and i have the front coilover at the camber plates maxed out so that i can have maximum SAI for switchback drifting, im running no front sway bar which gives me more roll so i compensate for that by adding more camber, probably a bit too much yea but idc cause it also looks baller and it feels good for me
no anything after -1* camber does not make it "darty" , the word darty seems to me at least refer to bumpsteer if anything and that has to do with traction rods and camber curve, not camber adjustments themself, although in my experience and from having done hours of research into the matter as well as talked to the drivers in my area -1.5 is about where the sweet spot is of camber and anything after that seems to lose traction
and as far as the camber wear, my tyres dont last much longer than a month cause i always destroy them drifting by then so i couldnt tell you, the ones i run up from have so much life in them for being on for 8+ months at that camber and being softer compound yokohama parada spec II
my car was aligned at firestone too BTW and just cause you work at an alignment shop dosnt mean you know anything about performance alignments IMO cause they didnt know much, i had to give them basically a step by step to adjust my alignment
sorry for the THREAD JACK!!
but yeah i would also have to agree with others when more camber is needed for the "flushness" look, i was speaking from a purely performance standpoint since i was referring to the kei office s15 which you can clearly see isnt running a lot of camber, but maybe a little more than 1 - 1.5 and a completely different look than flush cause you can tell it isnt flush ahhahaha
