s13drifter88 wrote:buuuuuut, if u look at the way their suspension compreses when they turn, the tire to the inside actually cambers in so its almost flat or flat on the ground. big difference between our cars. its like taking a car and setting it up for +.75* or +1* on the rear so when u launch while drag racing, when the rear end squats the tires camber out with squatting and theyre flat with the ground
your logic makes NO SENSE
when they turn the body roll makes the OUTER wheel flat, the inside would need to gain POSITIVE camber to be flat, NOT NEGATIVE, think about it...your making a left turn with negative camber your cars going to roll over to the RIGHT making your outer tyre flat and your inner one (following in the same direction) has less contact patch and even less if it cambers in more...so you would want it to gain positive camber if anything...
and your wrong AGAIN with what your saying... with your logic in drag, when your suspension compresses (squating) yes postitive camber would allow a flat surface when squatting since it will camber in...but your saying it cambers out?? no it dosnt it cambers in...squating=spring compression=lowering=negative camber...
^^^yes you were correct in this example but your explination as to why its set up that way is wrong which leads me to think you really dont know what your talking about
sorry
