can you shed more light on this. im aware of the box your talking about but dont understand how you fixed it? car still running good?spooled240 wrote:PICS:^ We routed a second nylon tube that goes to the internal breather separator under/inside the intake manifold. It's a small box that bolts to the front cover and has a hose fitting that connects to each runner of the intake manifold. I don't know if there is a check valve mechanism inside of it but just to be safe
and also on your cold side pipe that enters your t body you have what looks like small diameter ??vacuum?? line. what does that go to?
