Bearings? Why?sorrowfulkiller wrote:don't forget that you're gonna need bearings, headstuds, and it would be a good idea to swap out the water pump and/or oil pump depending on how many miles are on them
Headstuds couldn't hurt if they're stretched, but 5 seconds on a gauge will tell you that...and if ARP Studs were used initially, they are reusable anyways.
Water pump can be done easily when the motor is back together, and the oil pump stuff can go either way. Granted if you have the extra $100 when your front timing cover is off, do it.
