Didderson »
https://forums.nicoclub.com/didderson-u38557.html
Sat Feb 23, 2008 8:09 pm
Yes I definitely noticed a sound quality difference man ^ . I say go for it.We'll see how the headlight thing plays out, its too cold here right now for body work let alone laying paint.
UPDATE: A real one at that! This is my last weekend before returning to work every weekend so I made it count by changing my exhaust gaskets. I knew the one by the turbo was probably shot, and it turned out to be totally busted up. Here's a picture recap of my afternoon:
Pulling the manifold is a pain in the ayuss. It's the damn stock clips on the bolts that keep you plugging away for hours. I reccomend either pulling the turbo altogether or just having my level of patience for this job.
Just highlighting some of my polishing work and light port matching with the dremel today. Anyone who has stock manifolds knows theres casting marks all along the sides and also random sprue circles inside cyl 2 and 3. they're pretty much gone from where i could reach.BTW, if you decide to tackle this, make sure u have carb cleaner to help clear out the metal shavings as well as the carbon buildup when you're done dremeling. You don't want the shavings getting into ur turbine fins. At this pic, the gasket mating surfaces were already cleaned w/ a wire wheel on my dremel .
Turbo flange side, rough polish and gasket surface wire-wheel dremel cleaned.
Cleaned up the head-side gasket surface, again wire wheel dremel fitting. but this time the forward facing one. I have quite a collection of dremel fittings they really come in handy.
Masking off the turbo flange for wire wheeling;Cleannnnn!
steel wool and blow torched off the PB on the manifold for paint. we'll see how long the 1500* header paint lasts. Did the bolt washers too.
Man I LOVE the look of brand freakin new copper!
Daily project done, I'll post a pic of the original flange gasket in a sec. or lack there of. Overall, took me maybe 5 hrs taking my time, would have been much faster if the factory didnt put those dumb bent clips in the way of the nuts on the flange.
