Shimming a viscous doesn't make it a 2 way.troskinatior wrote:since your car is a hicas you have a vlsd. so instead of buying a open and welding it, you should shim your vlsd to a 2way, i heard good things about that.
Average life of tires will depend on the tire wear rating of that specific tire. But to give you an idea I dailied a welded diff in my old coupe on some brand new dunlop dz101's and they were gone after 7 months. Only 1/4 of a drift event on them with a stock ka in a smooth lot so they didnt get too much wear there.240sxJoe91 wrote:Generally what is the average life of tires with the welded diff. I would do this but my car is the super hicas so I would have to get the hicas delete kit before I did this....
Uhh, if you have one wheel in the air and the other on the ground you WOULD want your diff locked. Otherwise your a** is stuck. No open or helical diff will get you out of that situation.Bumnah wrote:
Actually, the Lotus Exige (quite possibly one of the best handling cars made) comes with an open diff, LSD is an option. Most people opt not to the LSD also.
Predictable is not what I would call a welded diff.
You don't always want the diff locked. Example, one wheel in the air, one wheel on the ground. You don't want it locked.
with the OEM 2 piece limp-a** driveshaft (i mean COME ON NISSAN, it has RUBBER as the joint between the two halves) and SHOT oem motor mounts, when the diff tried to rachet down and lock, the sloppy drivetrain took up the slack, instead of forcing the diff to lock down, and caused what i can only describe as "death rachet" movement/noise.pandapants wrote:Question.MGE, why did you hate your 2 way?Would you guys recommend purchasing other mounts or arms when welding your diff?How much of a difference does it make when you do upgrade those things?And why?
Apologies, improperly phrased. Depends on power level. Locked with one wheel in the air, you'll be putting power down on one wheel. That one wheel has traction. It is possible to spin out. Obviously it depends on the circumstances, speed, power.LayNLow240 wrote:
My view may be from a racing point.ILoveMyRHS13 wrote:Who gives a s*** if your rear end is planted or not? You're not going to do any circuit racing with a welded diff. Drift/drag only. You're looking at it from a racing point of view, Bumnah, and you can't look at it like that, haha.
To me, the Pros outweigh the cons. It's a drift car, it's going to break. NO fighting that. I've grown to accept that fact. I don't have $700-$1 Billion dollars to spend on an LSD. I'm sure once I make more money, I'll buy a 2 way, but for now a welded is the best alternative.Bumnah wrote:
Here's a couple of points from people in this thread.
Cons:It wears tires down quicker. If you have good tires in the rear (like I do, I run Falkens) it will put even more strain on axles. I haven't broken one yet, but I'm sure it's only a matter of time. Be sure to have plenty of extra axles. You can get them for -$3.The car fights you while turning.Turning radius goes out the window.
Waiting for an axle to snap....
Are these not big enough cons to a welded diff?
I'll admit, I like them. But a couple of minuets of sliding, and it feelings just like an open.s13beast wrote:vlsds ftw!!!1!
OK, you know what i ment, it makes it "feel" like a 2way. its better then buying a open diff then paying to weld it in my oppinionILoveMyRHS13 wrote:Shimming a viscous doesn't make it a 2 way.
For the record, all shimming a viscous does is lock harder. It will never "feel" like a 2 way because they're two totally different things. And again, when viscous' heat-up, they act as opens.troskinatior wrote:OK, you know what i ment, it makes it "feel" like a 2way. its better then buying a open diff then paying to weld it in my oppinion
I have yet to break one. You'll be fine.Salem240 wrote:I'm thinking of welding one of my spare open diffs this week, but before I do I have one question..... Exactly how many people have actually broken their axles with a welded diff on a stock KA?I'm just tired of looking like a douche when my car gets off camber when I accelerate and peg leg the hell out of it
is he a mod?AZ89two4Tsx wrote:Who deleted me and ILoveMyRHS13's little discussion?
I'm assuming OutToWinPAHC?
JOSH FOR MOD 2010!!!!hbpignosePA wrote:generally you shouldnt bring up crap that was deleted..... why not just drop the discussion?
Yeah, and is a little overbearing sometimes, in my opinion. Kinda tries to "censor" everything. Even the gray area stuff, which personally, I would leave alone. It's not a personal attack on him or anything btw, just my personal feeling about the situation. I mean, it's not like our debate was getting personal or anything.mrgreeneyes wrote:
is he a mod?
i dont get it....
I enjoy stating my opinion, and would hope everyone else does as well. It's a forum after all.
And on that note, that is ALL I will say about that. No use dragging something on that was deleted.
WOOOOOHHOOOOO
i did?OutToWinPAHC wrote:Nope not I, but being OP or not it certainly was off topic.... even when MGE set the thread terms.
Z32 rear diff cover allows you to hold more oil.TheBlaiant wrote:If i remember correctly, don't the Z32 VLSD's have an oil cooler on them? That would help out with the issue of VLSD's heating right?
I had a Cusco 2 way and sold it cause I didnt like the way it would go in and out of lock with the modulation of the throttle. In a long sweeping curve, say a highway on ramp, when I would slow down to get on the ramp then get into the curve and start to accelerate it would lock and start to push the car. Then when I'd release the throttle, while still in the sweeping curve, the diff would unlock and return open and stop "pushing". The diff made the car "feel" unsettled and less predictable. That is why I'm going to try the welded option, that way it will be constantly locked and predictable. And as for tire wear the cusco would make my 235's chirp and drag in the rear if I had to use the accelerator at all while parking. As for stability of 100% lock a 100% of the time.... yeah I have to be more careful in the rain and pushing into sharp corners, but atleast I'd know exactly what it will do and when..... all of the timerichiev8s13 wrote:never broke a axle oh and i just welded another one for the s14 i love them cant see spending the money on a 2 way for the same s***
