Thanks man, I really like the front fenders too with the "no vent" much cleaner. Also what is your underbody coated with? What did you do prior to applying the stuff? Sandblasting all of the dirt/surface rust off?Thankss13sillbeer wrote:Yeah, they're Wise Sport rear guards that have been riveted then fibreglassed into the standard body lines. The original guard is cut and shut on the inside to give the correct wheel/tyre clearance. Front guards are also from Wise Sport, however because I have a fender brace under there, it fouled on the guard vent, so it was deleted to give it a stock look.
There are plenty of companies that make wide guards of varying sizes and quality in Japan and China. The cheap stuff needs to come with a warning that the money you save on the guards/kit etc, you lose when it comes time to fitting in the body shop.
CheersBrendan
thanks for the update man, im super jealous especially the underbody man, POR15 right? And the stance looks so good, the molding job is great, oem looking.s13sillbeer wrote:Alright, finally got a little work done, so here's a blog update:
http://www.sillbeer.com/
And why is that?s13sillbeer wrote:nwmrkt:Yeah, POR15 Chassis Coat. Good stuff, but I'd spray it on rather than use a brush given another chance.
ic thanks, other than that its the same?s13sillbeer wrote:If you look closely, you can see the odd brush stroke.
thanks, once again props on the car, extremely clean.s13sillbeer wrote:Yep, same. There are some bits like brackets, subframe etc that I would powercoat rather than use a pressure pack (spray can) for longevity of the finish. But otherwise all good.
Panda Garage has an Aero front bumper in stock for $650 plus shipping...better buy it quick before I sell a Kidney for itcaldwmi2 wrote:man you werent joking that ****(nissan aero kit) is hard to find. Does anyone know who carries any of the wisesport gear in Ca.
You're not feeling the car much???? Why don't you post the pic of YOUR car, and don't talk TAKING cars, k pumpkin? Dang, people these days...olym wrote:i am not really feeling the car to much,i would take Broadfield's car over that one
