disrupt »
https://forums.nicoclub.com/disrupt-u59109.html
Sun Oct 21, 2007 8:03 am
Just putting my two cents out there.
what kind of steel are your flanges made out of? You are planning on similer material for the piping. If your flanges are mild steel and the piping stainless, it will be very hard to weld the two together let alone it survive the stress from heat expansion and weight of the manifold piping and turbines.
If both components are made of stainless. Mig tack, make sure you use similar mig wire and argon, not co2 gas. take it to someone with a tig welder and have them weld it place all sides continuous fillet welds. the tig needs at least a 200 amp power source to achieve full penatration depending on material thickness. stick is not great for tacking even with stailess electrodes because typically with stick went the arc to stuck the temperature has not reached an ideal temperature to produce a full penatration weld. you will get cold lap which is when the edge of the bead has lack of penatration and leaves a small overlap. Which if full penatration is not reached while fillet welded there is a chance that air or other impurities can be trapped in the weld which is where a crack will start. Better to weld a part with out a tack (regardless of mig or stick tacks), grinds off the tack and then continues to finish the tig weld you are okay.
Also while grinding, cutting with stainless wear a mask. your lungs will not be able to remove it over time like carbon steel filings.
Sweet project.
