The "I'm New Here And I have A Simple Question Thread" v2.0
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
allenms240 wrote:Stock bore, so 87mm 1.1mm thick cosworth?
I was considering Cosworth, just wanted to get another opinion, thanks.
Yes
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
i suppose i should check this thread out more often to help out
PapaSmurf2k3
Site Admin
^It would be appreciated!
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
just forgot about it lol, cause i didnt have it in my watched topics list.
idahotuner wrote:i suppose i should check this thread out more often to help out
Thanks dude! :dblthumb:
PapaSmurf2k3
Site Admin
We've had a lot of great contributions from normal members. SpeedEast definitely deserves kudos.
xHimeko
Sorry for asking so many questions but, since I can put an SR20DET in a 240sx, can I just import and S13?
PyR0NiAk
xHimeko wrote:Sorry for asking so many questions but, since I can put an SR20DET in a 240sx, can I just import and S13?
It would be cheaper and much simpler to just convert a S13 240sx...
PapaSmurf2k3
Site Admin
I'm guessing you mean import a silvia... basically the answer is no (legally). You can import one, but you can't drive it on the streets. You'd have to swap vins with a US 240sx or something, and have to put up with RHD.
speedeast
Car: 1990 240sx VH45 FB & 1993 300zx
PapaSmurf2k3 wrote:We've had a lot of great contributions from normal members. SpeedEast definitely deserves kudos.
Thanks! I try to help out when I can. What good is knowledge that isn't shared?
240man91
Car: 1991 nissan 240sx se hicas
Or just ka-t. Thats easy to
240man91
What do you guys think? Image
240man91
240man91
Ka-t running a god speed gt28 400 dollars for the turob. Works great spools nice for a cheap turbo an makes full boost at 2700 rpm an full boost is 15psi. An holds it all the way to 7rpm.
speedeast
Cheap turbo is asking for failure. I like the kit, but I'm not partial to the taillights.
PyR0NiAk
speedeast wrote:Cheap turbo is asking for failure. I like the kit, but I'm not partial to the taillights.
:werd:
And I would go with kouki tails...
PapaSmurf2k3
Site Admin
+1... and it looks like your rear wiper is a funky design/color.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
tint the tail lights they wouldnt be so bad then
240man91
Yeah i bulit it all got that cat out of a pasture less then a year ag. It was just sitting an roting i have almost got it all restored now just a bit left to go like finsh up the body kit. It is a hicas an has no rust anywhere. An everything works on it like it should. An the rear wiper is a dobble blade wiper.
MRiggs
Car: 89 240SX
sr20det S13 built S13 block with built S14 head
I am trying to get an answer to a question. I was under the impression that the BOV should be located on the hotside pipe. My friend is being told that it needs to be on the Coldside pipe. What is the answer here? If it can go on either side what are the pro's and con's to each? Thanks for the help
PapaSmurf2k3
Site Admin
Cold side is generally better because it takes any pressure drops through the intercooler out of the equation (less likely to buck), but sometimes if you run a blow-through MAF (like me), you don't always have room to put it over there.
So pros for cold side:
More stable operation (but sometimes that isn't really a factor with a good BOV and good piping system)
Cons: sometimes limited space, tough to find a vacuum line to T into?
Pros for hot side:
More room to play with
Vacuum distribution block can come right off the brake booster, or anywhere else over there
Cons:
If you have a large enough pressure difference between your hot side and your intake manifold pressure, it could trigger the valve to open causing bucking issues.
MRiggs
Car: 89 240SX
Thank you for the clarification. When I was on Enjuku and FRsport it seemed like all they had for sale were hotside pipes with the flange already welded on. I would like to get all new piping that is decent with a flange already welded on for a greddy style BOV. Any suggestions there as well.
PapaSmurf2k3
Site Admin
Well you definitely can't go wrong with Enjuku. They have been a long time sponsor/friend of this forum. FRsport is a solid bet too. You might want to take a trip over to Advertiser's Marketplace to see if any of those places are currently offering a NICO discount.
...for what it's worth, I'm moving the blow off valve on my miata to the hot side.
speedeast
Hot side won't give you any problems as long as you recirculate.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
i have ran them on either side, and i perfer them being on the cold, side just moved it backover there actually Image
PapaSmurf2k3
Site Admin
speedeast wrote:Hot side won't give you any problems as long as you recirculate.
Recirculating shouldn't have any different effect on hot or cold side... especially if you run blow-through MAF or speed density engine management. In fact, with blow-through MAF you almost WANT to run it on the hot side and get it far away from the MAF (and decrease turbulence through the sensor).
...unless you know something I don't.
PyR0NiAk
The only advantage to recirculating is the reducing the split second your motor will go super rich from metered air being released into the atmosphere. (Your ecu still adds fuel for the metered air.) I'm currently running a Z32 MAF on my S13 SR with a HKS SSQV venting to atmosphere.
Noxy
Car: 1993 Nissan 240SX
1992 NX2000
2004 Sentra Spec V
Sorry to interrupt, but quick question even though I'm really not that new...
I was working on my car tonight and found an extra transmission crossmember in my trunk. I don't remember buying another one, and I don't know the letter code on it, which is crossmember "C". I know the one on my car is "B" and I've gotten one from a Skyline that said "A". Not really a pressing issue, but does anyone know what "C" is from?
Thanks,
Zane
speedeast
It doesn't make much difference from one side to the other. That buck you get on the hot side can be reduced by recirculating. I was commenting more on a draw-through rather than a blow-through or other alternative.
thomasjamal
Car: 93 coupe
Ok, so I'm not new but this seems like a simple question that I haven't found an answer to by searching.
I recently discovered that my Header is cracked. My exhaust has no flex in it so I want to add a flex pipe to prevent this from happening again (obviously I'll also be getting the crack welded). My only question is does it matter where in the exhaust system the flex is? Does it need to be between the header and the cat or can go from the cat to the back?
