The more I see, the more I want. Looks great.sidewayz alwayz wrote:a s13 with a vh45de +tt
Seems that the most popular option for going with a manual gearbox is to use the z32 6-speed with an adapter plate. There is a lot of information in this forum about this setup. There are three posts in the top of the first page alone regarding adapter plates. Just browse through the first few pages of this forum and you should find a lot of the information you're going to need.sidewayz alwayz wrote: . . . so if there is anyone that has specific info on . . . whats the go with the manual conversion dont hessitate to let me know.
Sounds like something is wrong to me. You should at least be able to get over 400HP even on ****house RB20 turbos.sidewayz alwayz wrote:more bad news got the car dynoed (au$300) by a good tuner (proven) and made liitle power due to the size of the turbos (stock rb20 ceramics)only made 292bhp (yes the guy that tuned the car does know wtf he was doing as well)
the guy i brought the car off claimed 480 which would seem closer to the money.
the car made this power at 5500rpm though on 7psi and them just fell in a hole just like an rb20 would . made awsome torque though
I have experience with both the VQ 6spd and the VG 5spd manual transmissions. I'm using the 5spd on my VH project because they regularly hold up to 500whp+ and the VQ 6spds have a lot of grinding issues simply pushing stock engines around as daily drivers.craigztoyz wrote:5 speed is bettter, less shifting. Both only have one overdrive gear, so 6 speeds, means 5 up to 1.1, and a 5 speed has 4 up to 1.1, so unless you are running 4.10s in the rear, you won't want it. I almost went with a 6spd from a new 350Z, till i researched the gearing.good post above mine.
the SEARCH button works great,
It's not heavier and more reinforced, it's just an R200 VLSD with larger diameter Z32TT style stub axles & 6 bolt flange.anyotherone wrote:I would reccomend getting your hands on a q45 VLSD if possible though, its a heavier more reinforced R200 variant
I'm not sure that I follow what exactly the discrepancy is but there are actually even two types of Silvia flanges on the R200. My 91 2400SX had the 6 bolt type ourput flanges (3 tabs with 2 bolts each). There is also the 5 bolt with 5 tabs outputs (1 bolt per tab). I think the 5 bolt one is stronger because the bolts can be bigger and there are more tabs (some people call them ears, whatever).anyotherone wrote:I see you are in the land down under, could the diff just be different from your 200sx as opposed to the US spec 240sx? They gipped us on everything else, I can imagine that would be the same as well.
No biggie, the biggest difference in the diff is what you said, pertaining to the half-shafts and axles, that's usually the part I break anyways.
Weld it!sidewayz alwayz wrote:what is the easiest way to make it locked
