tech on s13 vh45dett manual conversion
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
craigztoyz
Car: lots of unique hot rods, and customs, with modern engines, and a good truck to pull the trailer.
The final drive is 3.46 I believe? and will give you a better chance at traction.
And that is the ultimate goal of the project, to have a better chance at traction
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
SSDwellah wrote:I think the 5 bolt one is stronger because the bolts can be bigger and there are more tabs (some people call them ears, whatever).
5 bolt one would be weaker. Remember, when two surfaces are bolted together, it becomes the friction loading of the two surfaces that is the major force which needs to be overcome for anything to break. Thus the one with more bolts would offer a higher friction loading.
sidewayz alwayz
Car: s13 vh45dett / vh commodore 355 stroker
i aint that keen on traction most people drive cars that keep traction its not that much fun get my drift. i thought my nick would have givin me away. weird when you think about it isnt it.
sidewayz alwayz
ultimate goal get a life
DJButton
Car: 2010 Nissan 240sx
Who cares about other people's goals, you have a twin turbo VH powered Silvia. Yes the GT28 or 3071 both have standard T3 flanges so if there are RB20 turbos on it now they should bolt up. You'll need external wastegates unless you get them internally gate of course and you might need to re-do the downpipes.
sidewayz alwayz
you a dj? im am also what sort of tunes do you get into
Return to “VH45DE / VK45DE / VK56DE Forum”
