If you look at this site, Mike tells you how to do all the calculations.I did the same ones (originally from another site though).And got my #'s.
http://www.nissanperformancemag.com/march05/nerds/
Now when he plotted the "Match point" for the SR20DE at 20psi (2.46 Pressure Ratio) and 37.84 CMf (Un-Corrected Mass Flow).That throws him at the 74% effecientcy range.
But now I've also plotted the rest of the RPM range with the same Engine speed's I used here: ****(Corrected Mass Flow)**** (20psi / 2.46 P/R)
2,000 rpm - 09.57 lb/min (Beyond the surge line)3,300 rpm - 15.80 lb/min (Just to the Left of the Surge line)4,500 rom - 21.54 lb/min 72%5,500 rpm - 27.75 lb/min 76%6,500 rpm - 31.11 lb/min 76%7,000 rpm - 33.50 lb/min 75%7,500 rpm - 35.90 lb/min 74%
*** Just noticed that his "Match Point" marked on the map is 38 lb/min, it looks like he used the Un-Corrected Mass Flow ***
He mentions the following:
"If you want to plot more points you can do so by plugging in different RPM values remembering that no turbo is going to produce 20 psi at idle. I would figure for something between 4500 to 7500 RPM for the SR20DE."
Now for me 2,000 is definetly into the Surge area, and 3,300 is just beyond the Surge limit. On a T04E 60 tirm compressor and a T3 Turbine .63 A/R (trim unknown) @ 14.7 psi-1bar.Since I won't instantly get 1 bar off Idle-How much boost would I get at 2,000 rpm & 3,300 rpm (wastegate set to 1 bar)?Now If I can figure out what boost I'll have at these Engine speeds I can see how far I will really be into the Surge area.
Modified by Sil240 at 5:58 PM 4/13/2007
