Synthetic gear oil
sanioll
Car: Nissan 240SX SE
Toyota Camry
3. WTF does s13 transmission needs anyways? what does FSM says?
i really wonder waht kind of "grease" that mechanic put in there. Really wonder. he didn't even want to resurface the flywheel. Life sucks, but knowledge is power.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
yes. GL4 in all 240 trannys with brass syncros
Chingon
Car: 1991 and 1992 hatchbacks
ok I was gonna recommend syncromesh, but apparently it's a 5w-30 weight oil. Does the dealer carry gl-4 synthetics?
I ask because for vw folks, they seem to.
98s14inaz
Just run redline MT90. It is synthetic with some kind of frictional additive, rated at GL4. Apparantly it allows the syncros to work correctly. The gl5 stuff is too slick and thick and will damage the syncros. Not to mention the GL5 doesn't have the frictional additives that are needed for our trannys to work correctly.
Chingon
actually the reason the gl-5 damages the synchros is because gl-5 synthetics contain EP additives w/sulfate compounds which corrode brass and other yellow metals, not because of viscosity or weight.
sanioll
Toyota Camry
you know i checked the manual, and theres nothing about GL4-GL5 stuff.
it just says 2.4 liters, and thats pretty much it.
how do you konw our cars, ex: s13 with manual transmission needs a GL4??
98s14inaz
Because Nissan uses the same rwd trannys in most of the cars from the 90s. The only differences are gear ratios and bellhousings. Everything on these cars are modular. It is in the s14 manual GL4 only. There is a weight difference between the GL4 and GL5. The syncros have trouble pushing the thicker GL5 out when going into gear. Get a pamphlet from redline and read up. There is some really good info in there.
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
The second gear in my s13 shifts really hard. I am going to try some MT-90 gear oil. I hope that solves the problem.
sanioll
Toyota Camry
do you have any idea how hard it is to find stuff like this?
Not a single auto store had it, so i had to order it through Advance Auto Parts. will be delivered on Tuesday. They said Redline is really good stuff for transmission. $8 a bottle.
98s14inaz
Can't go wrong with redline. $8 a bottle is about right, you'll use 2.5 bottles give or take.
sanioll
Toyota Camry
Ok, finally changed my regular oil, since its winter now, i switched to 5w30 for 3 months.
since i was under there, i started searching for a drain plug on transmission. Dude, there's no freaking hole. Well, the hole is there with bolt pattern, which you can put a bolt in there, but no hole, it is metal inside.
So where the hell is the drain hole??
Here are the instructions to change it,
sanioll
Toyota Camry
IT LOOKS LIKE SOMETHING WAS THERE, BUT UNSCREWED NOW AND IF YOU LOOK INSIDE THE HOLE, IT IS METAL. I HAD A REALLY GOOD FLASHLIGHT FOR THAT MATTER.
HERE'S THE PIC FORM THE MANUAL:
sanioll
Toyota Camry
I am gonna take a pic under the car. Picture = thousand words.
Also, my buds made me drive this winter. Looks like i'm gonna have to drive this winter to ski resort and carry all the long *** skiis and a single passenger. I just dont wanna drive my nissan.
I wonder if i should change oil before then?? Its gonna be almost subzero temp out there. really cold.
240marcuSX
Car: E34 525i
E46 M3
is this ok to use in the ka transmission and j30 lsd???
http://www.store.yahoo.com/pha....html
Drifterxl
Car: 1990 240sx FB
i just recently bought castrol syntech 100% synthetic for my transmission. i wasn't aware of the GL differences at the time. so can anyone inform me as to whether or not this is a good gear oil?
240marcuSX
Car: E34 525i
E46 M3
you might have to go back to the store where you got it and look at it,
gl-5 = no goodgl-4 = good
Chingon
sanioll wrote:Ok, finally changed my regular oil, since its winter now, i switched to 5w30 for 3 months.
you need to use a 1/2 inch ratchet in the hole.
sanioll
Toyota Camry
what the hell is going on here? my car is up on the jacks in the garage, i cleaned it up in there; theres no ****ing hole. no hole.
its all metal in there. its a threaded thing, wfhere you can screw something on top of it, but no hole, i cleaned it, inside is totally metal. i tried to open it, but its freaking whole metal.
looks like i have to pull fluid out from the fill hole from the side.
sucks, my father took camera with him, when they left couple mins ago. damn!
all right i'm gonna take some pics, asap!
this sucks, how the hell am i supposed to change the ****ing fluid. you can't even open fill plug, its so shut. i gotta rent some good tools.
FYI, i got 92 240SX SE, manual transmission.
240marcuSX
Car: E34 525i
E46 M3
the drain plug is on the bottom of the transmission, when you look upward at it, it should be looking you dead in the face.
can anyone answer my question above pretty quick, i want to get this order through tonight! Thanks!
edit: bro if your still having this problem tomorrow, i can try to come by and help you out if you let me know where youre at.
sanioll
Toyota Camry
240marcuSX,
No pal, Do NOT!!
HERE:http://www.redlineoil.com/prod...ID=18
OR
redlineoil.com and click on:
gear libricants-->synthetic M.T. Lubricant-->and click on MT-90
this is what s13/s14 transmission needs, according to everybody up^ there, we need GL4 and it is a really good stuff. so redline mt-90 is 75w-90 and its a GL4.
So dont buy it.
240marcuSX
Car: E34 525i
E46 M3
thank you, thats just the answer i was looking for. ill pick up some mt-90 as soon as i can.
sanioll
Toyota Camry
OKAY, MY CAM IS HOME AND PICS ARE READY, SEE IT TO BELIEVE:
sanioll
Toyota Camry
heres the drain plug and filler plug holes. filler plug hole is a pain to open. so far i diddn't have the perfect key and tried it with regular wrench, but couldn't get it open. do we have to spray anything on it?
sanioll
Toyota Camry
Heres the drain plug or hole?? seems to me that it is a whole metal, part of the transmission. doesn't look like you can unscrew it from there? if so, how, and waht tool to use?
sanioll
Toyota Camry
oh well, look what i found, so that plug does come out as you see in below pic. BUT HOW TO TAKE OUT THE FILL PLUG? ITS JUST STUCK THERE!! SPRAY anything on it?
240marcuSX
Car: E34 525i
E46 M3
to get the fill plug off, i think i put a wrench on it and hit it with a big hammer to break it loose.
sanioll
Toyota Camry
I'm gonna drive 10-15 miles before doing anything. While transmission is warm, it should expand, and removing plug from warm transmission would be easy.
We'll see on Tuesday when mt-90s arrive.
Ubernoober
Excellent, you got the drain plug out. Now wipe the shavings off (its common to have them), wipe and clean the threads, and re-install the plug. It does NOT have to be super-tight. They are tapered threads (exactly like pipe threads) and will seal with moderate tightening. If it seeps, you can always tighten it a little more later.
If you cannot get the fill plug out with a cheater bar, you can always fill through the shifter plate. If you do fill through the plate, you must pre-measure the amount you add. Plus or minus a little bit is no big deal, but too too much or too little will not be good.
sanioll
Toyota Camry
dude, that drain plug is not mine on pic above, i found the pic on tihs forum.
theres no way i'm touching my transmission until after the trip. i gotta drive for 3-4 hours to this stupid ski resort. i dont want any problems, leaks.
i'm gonna need to rent some tools too. i dont half 1/2 inch ratchet.
nelson8708
is the pic above right. The one about how much gear oil to put in the transmission. You just fill it up until it is level with the drain plug?
