My assumption is that the answer is not known then.
You are adding significant braking force to the front brakes. Generally you would want your brake bias (the balance of front vs rear braking force) to be such that the front brakes lock up just before the rear brakes would lock up. This provides for the smoothest application of braking force and maximizes the utilization of all four tire's threshholds.
Of course that is the generalization - there are instances where you would want more bias forward or backward depending on the circumstances (trail braking, rotation on a rally stage, etc) hence why many competition cars utilize a valve to adjust brake bias in the car.
My question really is given equal sized tires all around before and after adding this front bbk how much has the brake bias shifted forward? Ideally if you have increased the braking force in the front by 20%, it would be desirable to increase the braking force in the rear by a like amount unless the car was previously unbalanced which has not been my impression of the 240sx. This could for instance be compensated for in part by the use of larger tires in the rear to increase the frictional impact of the larger tire patch.
More on the topic:
http://www.stoptech.com/whitep...e.htm
